just closed up 915 after rebuild: should gears seem stiff
replaced 1-2 and 3-4 sliders, 2cd dog teeth, and 1-2-3-synchros.
I closed up box, adjusted shift forks, now bench shifting appears a bit stiff. I think this may be normal as there is no Swepco lube in tranny. It goes thru all 6 gears (5 + rev), but is not easy. I did not do a compare with original before I took it apart.
I guess I'm looking for moral support before I mate it to engine and install.
Old 05-06-2007, 05:15 PM
lally911's Avatar
Mine was more difficult after replacing the same stuff last year. New parts with closer tolerances and fresh friction surfaces, coupled with no swepco, should make it tougher to bench shift. I think its normal.
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 05-06-2007, 05:39 PM
Super Moderator
cstreit's Avatar
Pretty normal. Might be stiff for first coupla hundred miles...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 05-06-2007, 05:53 PM
Immature Member
dentist90's Avatar
When I replaced the hubs, synchros and slider for 1 and 2, I noticed these gears were a bit harder to engage on the bench than than the gears I had not touched. This makes sense as the synchro rings on the other gears will be more worn and allow the slider to pass over them more easily. I would think in your case 5th should snap in just a bit easier than the others as you haven't done anything to it. It will be easier still once you have lube on them and you're using the leverage of your shifter rather than shifting by hand on the selector rod.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 05-06-2007, 09:23 PM
OK issue closed till in car. Yes 5th-rev are a bit easier.
Thanks for the encouragement
Old 05-07-2007, 04:12 AM
