Originally Posted by kenikh View Post
Slate Gray...period (pardon the pun):
on the road...
Old 02-10-2008, 11:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #261 (permalink)
gearhead
Originally Posted by emptyo View Post
I think this thread shows that just about ANY car is worthy of saving. Nice job on the wheel Lars.
I think it just shows that Lars can save any car. I don't know if even he thinks it's really worth it. You'll have to see mine. It's pretty damned bad.
I like the slate gray, a lot!
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-11-2008, 05:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #262 (permalink)
SCWDP911's Avatar
Hey Lars, how about something really different? Ruby Red. I mean you don't see it ev, well, I don't se, well, actually I DO see it nearly everyday!
Seriously, how about the orginal Ruby Red (Paint #6402, Code 015). It was one of the first 911 colors used I think. I only have this crappy picture, but I know someone here has an absolutely gorgeous example... maybe they will see this and post. It would definitely be a little MORE different for you car in my opnion. I still am amazed everytime I catch up on your work here. That car is going to be stunning. Your work sure is...
Shane
- 1984 928S
Old 02-11-2008, 11:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #263 (permalink)
SCWDP911's Avatar
here is a better one (pic that is)... not sure whose car this is but it is a real beauty...
Shane
- 1984 928S
Old 02-11-2008, 01:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #264 (permalink)
darnellsgarage
Looks like we are on same path. Here's where I am at.
don
Old 02-23-2008, 07:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #265 (permalink)
Jim Horton's Avatar
+1 on Slate Gray
Jim Horton
1970 911T
1971 911E Targa
2006 Porsche Cayenne
2018 Tesla S (blasphemy!)
Old 02-23-2008, 08:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #266 (permalink)
I am biased, but my 66 has Green Granite on it. Looks just like gray but has a little more to it. Doesn't look green at all if that is what you are looking for.
Old 02-23-2008, 10:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #267 (permalink)
Duckworth's Avatar
Probably not on the list - but a really nice color. Wow.......thanks fellow pelican.
Old 02-24-2008, 10:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #268 (permalink)
jasam's Avatar
One of the best 911 pictures ever...
1+ for slate gray
There is no substitute
Old 02-24-2008, 12:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #269 (permalink)
front suspension time
I hesitated to post until I had made some headway....underside is dressed and waiting suspension. Wurth underseal is applied and looks great. Brakes are rebuilt and ready to be bolted up. I rebuilt/restored the steering rack and added turbo tie rods. The rack was filthy...and needed a lot of elbow grease to clean up
tie rods are next
Sooo much easier to install on the bench than underneath the car.
I needed to incorporate aditional spacers for the earlier steering rack
Bump steer spacers
Old 02-26-2008, 09:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #270 (permalink)
Aluminum crossmember
Fits right up....I love these cars. the crossmember and front struts and brakes are off a 1986 carerra . The steering rack all cleaned up looks factory new with bump steer spacers installed
Old 02-26-2008, 09:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #271 (permalink)
The Aarms freshly powdercoated
And all the associated parts
Now to install the tbars...22mm in the front
And end fittings
Old 02-26-2008, 09:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #272 (permalink)
getting somewhere
22mm tbars
Cross member, and tbars/bushings installed
Old 02-26-2008, 10:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #273 (permalink)
Struts
fresh turned rotors
cleaned up dust guards
Adding the calipers
Old 02-26-2008, 10:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #274 (permalink)
finally
These were painted on the bottom and primered on the top. The trunk will get painted body color, and where the struts bolt up will need to be disassembled and repainted when the car gets back from the painter. I just wanted to get them ready for the struts to be mounted up.
struts getting ready
Old 02-26-2008, 10:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #275 (permalink)
BlueSideUp's Avatar
Send a message via AIM to BlueSideUp
Nice work! Is your underbody protection essentially POR15 with Wurth High Build on top of it?
-Jess
Old 02-26-2008, 10:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #276 (permalink)
finally
New correct ball joints for the carrera struts/calipers
Replacing th ball joint is soooo much easier upside down
Now the tie rods
Done
Old 02-26-2008, 10:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #277 (permalink)
last work with struts
The brake lines and sway bars will go on after painting...less to mask off
Old 02-26-2008, 10:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #278 (permalink)
lateforlunch's Avatar
good stuff dude
Old 02-26-2008, 11:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #279 (permalink)
Grady Clay's Avatar
Lars,
I recommend you use a ’69 and later steering rack with your setup (even after all your hard work
cleaning the early one ). The two racks are slightly different ratio and you will notice a
significant difference in ‘feel’.
The ’65-’68 is about:
1.65:1 and 2.8 turns lock-to-lock.
The ’69-> is about:
1.8:1 and 3.0 turns lock-to-lock.
While everything is easily accessible, you should repair the aluminum cross member (red arrow).
That little piece of aluminum is what retains the height adjusting lever keeping it from working its way
off the torsion bar splines and lost.
Another is to test the range of adjustment of the caster-camber plate. You may want to remove some
metal on the chassis where the clamping bolts contact the edges of the openings.
Remember to grease the bores in the struts, the wedge pins and ball joint pins.
Looking good!
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 02-27-2008, 06:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #280 (permalink)
