Clicking noise
I had a great drive today from central Jersey to Brooklyn, NY.
All went well except for a faint clicking noise emanating from the driver's side rear wheel.
Only heard when close to a barrier that makes the sound bounce back. No grinding or vibrations. Sounds like wheel bearings.
Is this normal or am I looking at replacement soon?
Thanks,
Q.
2004 996 TurboS Cab
2005Cayenne Turbo S
1988 930 Turbo Cab
2004 BMW M3
2007 Range Rover Sport
Old 05-06-2007, 06:35 PM
jbrand540's Avatar
If its centralized to one side of the car it is probably loose valves. When were the valves adjusted last?
Old 05-06-2007, 07:07 PM
A long time. I've had the car 2 years now and haven't done it. No problem with acceleration or pinging. It sounds like a possible culprit though.
Thanks,
Q.
2004 996 TurboS Cab
2005Cayenne Turbo S
1988 930 Turbo Cab
2004 BMW M3
Old 05-06-2007, 07:21 PM
jbrand540's Avatar
If its been 2 years then the valves should be adjusted. Its the first thing that I would check.
I adjust mine using the backside method outlined in the Pelican Tech articles. After 2 times of doing it I can adjust them in about 3-4 hours including the hour + it takes me to get everything out and back in just to reach the valves.
Old 05-06-2007, 07:38 PM
bigchillcar's Avatar
sounds like cv's or wheel bearings.
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-06-2007, 08:01 PM
jbrand540's Avatar
I was assuming this was with car stationary next to wall is this while in motion?
'89 Carrera Cabrio
'01 Audi A6 2.7t
'01 BMW 540i
'06 Dodge Ram 2500 Diesel
Old 05-06-2007, 08:04 PM
Semper drive!
rcecale's Avatar
+1
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 05-06-2007, 08:15 PM
Yes, the noise is while in motion.
Q.
2004 996 TurboS Cab
2005Cayenne Turbo S
1988 930 Turbo Cab
2004 BMW M3
Old 05-07-2007, 04:03 AM
911mot's Avatar
A stone stuck in the tyre tread
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 05-07-2007, 04:04 AM
I had something like this once on my 72 targa. It turned out it was the e-brake cable rubbing on the back of the wheel. The mount broke so I had to use some wire to hold it in place. Possible?
72 911 T Targa 3.2
01 Boxster S
Old 05-07-2007, 05:49 AM
Worn sway bar bushing...
Old 05-07-2007, 10:40 AM
goober's Avatar
My 84 Carrera track car is doing the same thing. Is not related to engine speed. (if I push in the clutch at speed the clicking frequency does not change) Mine is definitely coming from the driver side rear also.
Old 05-07-2007, 11:58 AM
Before doing anything expensive, check your tires for stones in the tread or some metallic object embedded in the tire. I've had the same symptoms numerous times and it has always been either a stone in the tread or a nail with its head still intact. Even with a nail embedded in the tire, you may not loose any air (at least for a while, so check it soon).
Doug
'79 911 Turbo
"My destiny's ta' get the hell outa here."
Henry Fonda - My Name is Nobody
Old 05-07-2007, 02:12 PM
Tired Member
DaddyGlenn's Avatar
Important question - Does the speed of the clicking change in relation to wheel speed or engine speed?
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 05-07-2007, 02:27 PM
