Question Converting to -AN - what to use on block??
I know why, right? I'm converting a '74 914 to 3.0 6 and I'm using after market oil tank, cooler, ect. I've already taken car of the oil cooler connection, just had a 90 deg. fitting welded on. But I can't seem to find anything to replace the fitting on the case?
Anyone, BTDT, and can give me a suggestion, or what you used.
-Mike D.
'74 914-6
'94 968
Old 05-07-2007, 10:18 AM
North Coast Cab's Avatar
Smart Racing has all the adapters available. You can go to AN16 from the case and go from there.
J
1985.5 944 GTS
Old 05-07-2007, 11:07 AM
I may have found what I need from Patrick Motorsports....
-Mike D.
'74 914-6
'94 968
gestalt1's Avatar
i bought an an-16 hose fitting from BAT, it is a forged 90 deg fitting so it will fit on the 30mm fitting on the case and clear the headers. i had to use a strap wrench to tighten because it is a tight area. i think the fitting was about $75 and the patrick and smart fittings are likly the same part. i used a strait fittin for the oil tank, no 30mm to an-16 adaptor needed.
-matt
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 05-07-2007, 11:40 AM
