dshepp806's Avatar
Yep,..just slightly in on my 89 gets the job done,..sometimes a slight angle maybe..
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-10-2007, 02:16 PM
Depends on the station or the pump. Some stations it goes in normal, some stations I gotta flip it 180*.
-Steve
'87 Carrera Targa
Old 05-10-2007, 03:00 PM
AUGHHH, I only go for 90 degrees clockwise! AM I NORMAL!!???
66 911... no more
90 mazda miata
76 unimog 406
Dune Buggy!
Old 05-10-2007, 05:24 PM
Oliver Klosov's Avatar
Imagine it as a sacrament. You are consecrating your 911 with the blessing of speed and fun! If you have to fill slowly, consider it part of the karma strain. Relax, it will pass. It might take some time to fully appreciate what is yet to come... Listen to the sound of anticipation. Do you hear that: "Glug,glug..."? Yeah, it costs some, but the return is priceless!
'79 911SC Coupe
We may be lost, but at least we're making good time...
Old 05-10-2007, 08:13 PM
I go for a straightforward stance with feet about shoulder width apart. This is after all, a utilitarian excercise. I usually avoid eye contact with my counterpart in the other aisle. Then I finish with a shake and put the unit back in it's proper receptacle. If you're not gentle here you're not gentle anywhere.
Wait a second, what are you guys talking about? I'm talking about putting gas in my car.
Old 05-11-2007, 12:09 PM
