Born to Lose, Live to Win
ramonesfreak's Avatar
Odometer problem
Hi..just noticed that my odometer and trip meter stopped working sometime in the past week. everything else seems ok. Had new tires put on just prior to it stopping. Any ideas or things I can check for? Thanks alot
-Scott
Old 05-11-2007, 02:53 PM
Sultan of Sawzall
rouxroux's Avatar
The dreaded plastic odo gear. You can buy a new gear yourself and put it in, or send it off to one of the many gauge shops.
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 05-11-2007, 02:59 PM
Thanks. So much to learn with these cars. Everyday presents a new project but i like it. Is there are tech article on here that will describe how to take apart the speedo so i can confirm its the gear?
Thank you
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 05-11-2007, 03:02 PM
Mine did the same thing. I sent it out to Palo Alto Speedometer and it came back looking like new. I thnk it was arounf $140. After reading the DIY stories, it was well worth it in my book.
http://www.paspeedo.com/
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 05-11-2007, 03:16 PM
Sultan of Sawzall
rouxroux's Avatar
Yes. Go to the top of this page and click the yellowish tab marked "Tech Info Center", then scroll down through the 911 tech articles until you get to gauges. Not too hard, just time-consuming and a bit nerve-racking. If you take your time taking the bezel off, you'll be fine. But if you don't feel like a DIY, there are plenty of great repair shops.
Gruppe B #319
Old 05-11-2007, 04:36 PM
im pretty good at DIY and ive already ordered the gear, assuming thats what the problem is..ill just have to look up some step by step instructions. thanks all
1983 911sc
Old 05-11-2007, 06:27 PM
