wheel sizes on an early car
i've checked Bill V's guide and don't see what i'm trying to do.
i have a line on a set of 16x7 & 16x8 fuchs and am wondering if they will fit on a '73 with no flares.
can anyone with more experience help?
Chris
the more i learn, the less i know
Old 05-08-2007, 04:54 PM
304065's Avatar
225 tires on 6" rim??
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-08-2007, 05:02 PM
They will not fit, I tried on my 74 without flares, went down to 16x7 all the way around.
Phoebe's progress (thanks to many Pelicans)
see bottom pic with 16X7's
1974 911 targa 2.7 (for the road)
1974 FJ40 Landcruiser (for no roads)
1995 Dodge V-10 HD2500 4x4 (to tow anything I want)
2005 Durango (wifes rig, I've driven it twice)
2000 Fisher Freedom 200 w Mercury 115 ELPTO (because the world is mostly water)
Old 05-08-2007, 05:16 PM
how much negative camber or lip rolling would be needed. i guess 16x 7 will work on the front.
Chris
Old 05-08-2007, 05:40 PM
barney911rs's Avatar
I'm pretty sure you can't fit an 8 15 or 16 in the rear without flares. The best 7 for the rear would be the 911R offset. I don't know what it is, but I'm sure someone on here can tell you. Suspension settings, ride height, and tire selection will all influence if something will fit. Good luck.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 05-08-2007, 06:02 PM
The offset is +23 sorry I should have mentioned that
Old 05-08-2007, 06:21 PM
Bland
unclebilly's Avatar
the 17s off of my 77 wide body fit my 71 in the back but then the 71 had no motor in it...
Old 05-08-2007, 06:40 PM
Zeke's Avatar
He's a funny guy folks....
Tyson Schmidt could get those 8's on, but it takes some work. If you are ready to run 2.5 degrees neg camber, the rest could be discussed. Not for the faint of heart; some serious tweakage involved where the trailing arms attach to the torque tube.
Otherwise, just do the 7's and pick your tires carefully.
Old 05-08-2007, 06:48 PM
haycait911's Avatar
I tried for two years to get 8X15 to work on the back of my '73, rolled lips, no flare. 2-1/2 neg camber and the smallest reasonable tire size still led to burnt paint and grooved tires. now have 7x15 all-round with replicas on the back, no problems whatsoever. BTW anyone got a pair of 7x15's they want to part with? will trade my 8's. Don.
Old 05-08-2007, 07:16 PM
pwd72s's Avatar
7's are a tight enough fit...forget the 8's without flares.
Old 05-08-2007, 10:48 PM
Dan Morton's Avatar
I tried 16x7s on my 1970 911 with no flares and it rubbed on the back and stuck out on the front looking a bit odd to me. I opted out of the 7's completely and went back to stock wheels for now.
Like others have said, you can try to get the 7's to work in the rear by rolling the fender lips and adding negative camber.
-Dan
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
1997 993 Targa (sold)
Old 05-09-2007, 10:18 AM
klaucke's Avatar
You will need 951 8" Fuchs to make this work. They have more a deeper backspace than 8" 911 Fuchs, and therefore give more lip clearance, which is where the problems arise for 8" 911 Fuchs on early narrow body cars. Member Ischmitz is running 8" Fuchs on his '74 w/ 3.6 swap, and Marco, Mr914-6 I believe is also using these wheels-- see his recent thread on Treffen '07.
16x8 Fuchs on a narrow-bodied Targa
7" Fuchs on the front pose no problem, either 911 or 951, the latter having more caliper clearance and a lip that looks like a 6" Fuchs, with deeper lug holes.
Old 05-14-2007, 01:57 PM
