16x8 Fuchs on a narrow-bodied Targa
I just wanted to share a little success story in my ongoing quest to get the Targa more suitable for the track.
We installed 16x8 Fuchs 951 in the rear with 225-50-16 Kumho MX and put the 16x7 with 205-55-16 to the front. With the addition of a duck tail and a strut brace the car is totally transformed. It turns in great, corners awesome and at high speeds the stability is greatly improved. As a bonus I get much better cooling. A well-known capacity in 911 expertise opened his bag of tricks and did a great job to get me closer to a track-ready everyday-driver. Willow Springs I am ready. Cheers, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
PRO Motorsports
Boy, whoever helped you with your car must be a GENIUS!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
and Tyson.. I'm presently doing the carb plumbing as per your advice of a continuous loop. I'm using the Holley fuel regulator after the carbs/ before the return. I also found a large 5# gauge. Richard Parr wants a pic when completed for Maybe using the pic on his site. Thanks again for straightning out what I need to do.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
so what does the 951 difference translate to as opposed to a regular 911 8" wheel?
dave 1973,5 |
PRO Motorsports
Very cool Ron! I hope it goes well.
Yeah, I had to crank in about 3 degrees negative camber for clearance. But dang, that thing oughta stick in the corners now!
RETIRED
Should get about 3,000 miles outta them Kumhos.....%^B
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Actually the offset on the 951 wheels is 23.3mm and the offset on the 911 is 10.6mm, but the effect is push the wheel inboard, ljust like a 7x16.
Nice work, I could only get a 225/45-16 in. How much neg camber do you have, and how is the oil line clearance??
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
Schleprock
-3 degrees. OH yeah.
I think you're going to like those Kumhos. I feel they're excellent tires. Compared to other tires i've driven on in the 911 (Goodyear Gatorbacks, Yoko ES100, Sumitomo HTRZII, Dunlop 4000), these tires have much stiffer sidewalls and are much more responsive. Grip is great and they start with a bit less tread depth than your typical tire. Excellent tire for the money in my opinion. And they look cool. Wish more people would try them! Be sure to post your impressions of them to enlight other people.Oil line clearance should be fine. Had no problem on my car with the same basic wheel (actually a 16x8 +23.3mm o/s 951 phone dial) shod with a 245/45 Yoko ES100.
Kevin L '86 Carrera "Larry" |
I wish I could have seen this thread _before_ I stuffed my 15x8 Fuchs under the rear of my narrow body Targa. I could have saved myself the horror of denting the crap out of my fenders from the rolling. Ah well, whats done is done. Amazing how much of a difference an inch makes in the feel of the car though, huh? The 15x6s made it drive like a wet-noodle, but the 7s and 8s transformed it into a rock-solid autobahn burner.
m.
'75 911S 3.0L '75 914 3.2 Honda J '67 912R-STi '05 Cayenne Turbo '99 LR Disco 2, gone but not forgotten |
Iscmitz and Marc:
So if the *offset* is the same...then the *backspace* for the 1" wider rim puts all of that extra width on the inside...... ---Wil Edit: I need to make a correction: 8" 911 piece is 10.6mm offset, 112 mm backspace 8" 951 piece is 23 mm offset, 125 mm backspace. If this is true...then the 951 piece places the wheel about 13mm ( say, 1/2") closer inboard than the 911 piece. Sorry....
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 05-19-2004 at 09:28 AM.. |
look at the 2nd and 4th from the bottom wheels in this diagram. ![]() They have the same o/s but one is 1" wider than the other.
Bill:
I think your post and my correction crossed in cyber space... --Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
He has devised a way to install 8" fuchs on a narrow body 911.. "BRILLIANT!"
![]() Eric
Famous last words.. "Hold my beer and watch this...' " The reason the Irish are always fightin one another is that there are no other worthy opponents ". |
Administrator
Maybe the secret is to avoid straight roads at all costs.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Licensed User
Nice job Ingo! How much room to have left between you tires and the spring plates?
Have you guys seen the custom 2 piece 8s on the front of Mark's Duck? Bigger offset, pushing more of the wheel inside. I think they would work on the back of the narrow arse cars without too much trouble. Last edited by Shuie; 06-23-2004 at 10:52 AM.. |
Which Mark's? Any pics? Dimensions?
dave 1973,5 |
Licensed User
![]() Need some opinions on Fuchs sizes, maybe some pics? |
