How do I keep my rear camber from changing?
I have had a problem with the right rear of my 1980 911SC (with a steel widebody) changing camber settings when autocrossing for quite some time now and nothing I try seems to fix it.
I'm sure that the 275/40/R17 Hoosier autocross tires on 11" rims on the rear do put quite a bit of stress on the suspension but why would the left side be OK? I've had the camber shift positive enough to have the tire hit the fender wall which is unaccepable. I've replaced all the bolts including the eccentric twice with OEM parts, I took the trailing arm apart and cleaned it up, and even over torqued the bolts trying to make it stop. Here are a couple of dumb questions that I have never found out the answer too as there aren't a lot of 911's involved in competition around these parts. 1) Is there any chance that between the plates on the trailing arm there is supposed to be that caulking stuff like on the front strut mounts? (I told you these are dumb questions...) 2) My aftermarket swaybar is attached to the end of the eccentric. Having never seen where a factory rear bar mounts or where other swaybar manufacturers mount theirs, could this be the cause of my problem? 3) Is their any chance that I could add the Rear CamberMax kit that Pelican Parts sells to help the eccentric keep it's setting?Any thoughts? The season's about to begin and I don't want to be stuck under the car adjusting it between runs again. Thanks S.Chapman A/SP 911 C/S 914 E/S 944 |
Have you ever checked your bushings?
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
I replaced the spring plate bushings with Neatrix last year and the rear trailing arm inner bushings on the bannna with Delrin the year before...
Thanks S.Chapman |
Is the camber eccentric bolt turning? If not I don't see how you could be getting a camber change unless you are exceeding the range of the camber eccentric. The Delrin inner bushings cause the suspension to bind especially with large negative camber settings. Maybe this is part of the problem. My sway bar hooks up to the toe excentric bolt hole. Maybe yours is supposed to be there as well.
-Andy
72 Carrera RS replica, Spec 911 racer |
PRO Motorsports
Yeah, I'm with Andy. The inner banana bushing needs to either be rubber, or a mono-ball, period.
The arm needs to be able to twist as it moves through it's range of motion. The plastic solid bushings don't allow this, and will eventually break apart. It may be the core of your problem here, but it's hard to say.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
You can almost see the wheel starting to move in this picture: Quote:
I haven't autocrossed this car in a few years as I'm concentrating on my CS 914 but I took it out to a club event on street tires (2nd place overall FTD out of 30 cars Any more ideas? Thanks S.Chapman |
PRO Motorsports
Yes, the poly-graphite bushings bind as well. Switch to mono-balls at your next opportunity.
The rotating camber eccentric is odd to say the least. Are you using the Schnorr washer under the nut? Although I can't imagine why it would turn even without this lockwasher.
I'll do that. My front torsion bar bushings also need replaced so this would be a good time to take care of it all at once. Maybe the bushings I replaced originally were not rubber?
I swapped out the eccentric, washer, and bolt with new ones. If I remember right the washer had a bunch of little teeth cut into it. I can't understand why it turns either as wouldn't I be correct in assuming that the eccentric just positions things and the locating bolts holds everything in place? BTW I just looked under the car and noticed that the toe adjustment has no way to connect to an end link. Any chance that these eccentrics are interchangable and a mechanic got them swapped? Hmmm... I'm starting to think that I have two problems that are creating one big one Thanks S.Chapman |
Re: How do I keep my rear camber from changing?
My advice is to torque to factory specs. More is not better. Is your wrench properly calibrated? There are 3 clamping bolts, make sure they are all properly torqued. Make sure they all have correct lock nuts. Lose the plastic bushing. The cambermax won't solve the problem, it is designed to easily setup the camber but not designed to support the weight of the car.
Chuck Moreland - elephantracing.com - vonnen.com Last edited by Chuck Moreland; 05-17-2007 at 07:45 AM.. |
Good advice! Where's the 3rd mounting bolt? Going by memory I can only think of the two on the end of the spring plate fastened by part# 27, 30, and 28
Thanks S.Chapman |
Diss Member
The 3 bolts are clearly shown in the picture. They are #27, #31, and #32.
31 and 32 are the special eccentric bolts.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Czar of C.R.A.P.
I would say take the sway bar off the ecentric bolt and mount the sway to the trailing arm.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
From what I see in the diagram, the clamping bolts are 2x #27 and #31.
#31 is the camber eccentric bolt which does double duty, both an adjuster and a clamp. The toe eccentric #32 does not clamp, it only adjusts. And it is bolted to the spring plate only, not the trailing arm. Hence moving the sway bar off the toe eccentric will not help.
Chuck Moreland - elephantracing.com - vonnen.com |
Wouldn't #33 be the clamping bolt for the ride height side of the plate?
I thought #31 is the eccentric for ride height? Just checking. -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Czar of C.R.A.P.
If he still can't hold the settings perhaps get everything set and tight. Then remove the toe ecentric and replace with a bolt, 2 washers and a nut. That should clamp the two plates.
Czar of C.R.A.P.
Never mind the nut and bolt idea there is no room on the back side for a washer.
Here's the full link with the parts list I got off of our Host.
-There are two #27's that hold the bannana arm to the spring plate (the second bolt is not shown but goes in the top hole) -#31 is the Camber eccentric (and third locating bolt ...and what my swaybar is attached too) -#32 is the Toe eccentric Ride height is only fine tuned by adjusting the bolts on the spring plate that aren't shown on that diaghram. Hopefully this will help with the confusion. Quote:
Thanks S.Chapman |
We'll I just ordered up some Elephant Racing monoballs and bolt hardware from Pelican Parts. Here's hoping it solves my problem!
Thanks for all your help guys! S.Chapman A/SP 911 C/S 914 E/S 944 BTW has anybody ever come up with a way to attached their rear swaybar directly to the trailing arm instead of the eccentrics? |
If I remember correctly I believe the race shop that does my alignments replaces the two large clamping bolts every alignment. In fact I think they may have even commented that if the clamping bolts are doing their job, the alignment bolts can be removed.
'83 SC |
It's been a few months since posting this question about my de-cambering rear ...but I thought I should share with the board that the Elephant Racing monoballs did the trick.
It took me a while to source all the bolt hardware, get it installed, set the corner weights, and align it all up again ...but it all paid off with a really good showing at the Slalom at Slemon in PEI this past weekend besting a gaggle of S2000's, 350Z's, Vette's, M3's, etc... Why do they even sell the plastic inner bushings? After I disconnected the trailing arm it was quite apparent that the inner banana arm would only move in one dimension causing a major bind in the travel. Here's a picture of the same type of corner as at the Cdn Nationals but the rear tire is staying put. ![]() Funny side effect since I installed the rear monoballs, front strut monoballs, and the torsion bar polybronze bushings though... my front tire doesn't lift as much as it used to (even with the exact same swaybar settings) Thanks for all your help guys! Stacy A/SP 911 |
