Lightbulb Headlight stalk problem- won't flash
Hi guys,
I've got a problem with my headlight stalk. All other functions work, except the high beam flash.
The contacts on the stalk are all in the correct position as per this post:
turn signal switch quick fix pictures
and this picture from the post:
I'm thinking it's a problem with the stalk itself. Any chance i can open it up and fix it?
Anybody have any other ideas?
Thanks a lot,
Adam
_____________________
'73 RSR Interpretation
Old 05-17-2007, 11:23 PM
scottb's Avatar
Others have reported that they have opened the switch and cleaned and repositioned the contacts. I don't think it's worth the hassle...I simply replaced my switch when I had similar sypmtoms.
1984 Targa
Old 05-17-2007, 11:27 PM
randywebb's Avatar
can you try blasting it out with an electronics cleaner aerosol?
then check the price in Aussie-landia to see if it's worth your labor...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-18-2007, 10:11 AM
That's a troublesome unit. I simply changed mine out when it started malfunctioning.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 05-18-2007, 10:58 AM
I've had success in the past with bending contacts,
But this time it's not working. Looks like i'll have to find another stalk...
Old 05-19-2007, 09:31 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
You should eliminate the problem with relays that bypass the stalk switch for your headlights.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 05-19-2007, 10:03 PM
yer i know about the sucro kit. I will look into it once i get everything going again
Old 05-23-2007, 04:26 PM
kbruz's Avatar
Replace the stalk. You'll be alot happier
kb
mercedes GLK350
2009 boxster s
86 targa
Old 05-25-2007, 09:46 PM
