Dave Hanning
earlyaircooled's Avatar
Spark plug questions
I have a 67S and a 69E and Bosch says to use the platinum plugs W3DPO for both cars. Problem is these plugs cost $14 each. I have some nos Bosch W250 P21 the original owners manual says to use : W265 P21 or W265 T2SP.
I have a few questions:
1. Will the nos W 250 work? In other words is it that different than W 265?
2. Is the W3DPO the best modern plug to use?
3. If I do need to use W3DPO is there somewhere I can get them for less?
Thank you,
David Hanning
1975 Carrera coupe
1974 Targa
1998 Boxster
1999 Boxster
Old 05-18-2007, 09:58 PM
WydRyd's Avatar
A cheaper alternative to the W3DPO's are W3CS... same heat range, just a copper plug, instead of platinum. 3 heat range plugs are too cold anyway (street or track), so you could easily move up a heat range to a W4CS or something.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-18-2007, 11:16 PM
David:
W3CS plugs are silver, not copper ones, and while very good for sessions of WOT, I'd recommend the W4CS as a more practical choice.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-18-2007, 11:20 PM
WydRyd's Avatar
Doh, sorry, yes silver!
Merv
'89 911 Turbo Cab
Old 05-18-2007, 11:23 PM
Dave Hanning
Great info, thank you. A local supplier actually sold me WR 4 DPO and I was going to get mad and send them back for Bosch's recommended W 3DPO but if I'm reading this right sounds like WR 4 DPO is a better choice for 67S and 69E. In the future I'll get the silver W4CS to save some $.
Any idea if the nos W 250 platinum will work for my cars? Is the W4CS definately better since I have a good supply of the W 250 on hand.
Thanks again,
David Hanning
Portland OR
1975 Carrera coupe
1974 Targa
1998 Boxster
1999 Boxster
Old 05-18-2007, 11:42 PM
WydRyd's Avatar
Even the warmer FR5DTC or FR6DLC /DTC's would work fine. Those are used in the 964 and later model engines. They'd certainly burn cleaner and resist carbon deposits better than the colder 3 or 4 heat range plugs.
I run FR5DTC's in my big boosted 3.2 motor and they perform great. If I was tracking it though, I'd run a 4 heat range, but for street, 5 or 6 is fine too.
Merv
'89 911 Turbo Cab
Old 05-19-2007, 12:46 AM
