RBS RBS is offline
Unhappy 3.2 Hot Start and Stalling Problem
I think I have a couple of related problems with my ’87 Targa. The first is a hot start problem. Once the car is hot if I turn it off it will not restart right away. The engine will turn over but it won’t catch. If I let it set for about 5 minutes it will start again. Last fall I had the CHT sensor replaced which did not solve the problem. Last night it started stalling at speed on the highway. It happened twice within about 15 minutes. If I let it sit for about 5 minutes it will start up again. After reading the archives this is what I am thinking about doing. Replacing the DME Relay and the Fuel Pump Relay. If the problem persists then I am thinking it is the fuel pump or the DME module. Any other ideas or suggestions?
Rob
Old 05-19-2007, 06:27 AM
Irrationally exuberant
ChrisBennet's Avatar
The DME relay is 2 relays internally - the DME relay and the fuel pump relay.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-19-2007, 08:11 AM
