Power window problem
My passenger side electric window stopped working this weekend. I am assuming it is the window regulator that is the problem. How big of a job is it to change it out? Can anyone direct me to step by step instructions on replacing it?
84 Carrera
1984 Carrera |
I would check the switch first before assuming the regulator is bad.
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
AKA SportsCarFan
I had an intermittant problem with my driver's side window last year. Turns out it was the switch.
Doug Miller 1988 Guards Red Carrera |
I dont think it is the switch. Both with passager and driver side switches I have downward movement but not upward. The window has been slower than the driver side for awhile now.
If one switch was bad would it affect the switch on the other side?
1984 Carrera |
Nick '85 Carrera |
It looks like the motor is the problem. How hard is it to replace?
1984 Carrera |
I had EXACTLY the same symptoms. Would only go down, not up. It was the passenger switch and it affected the driver's side switch.
Shoot, as inexpensive as switches are, I'd always try that first. Quote:
Meka
Tcar is right, the same thing happened to mine. And one switch did affect both windows. Been awhile, I replaced both switches and no issues. PLEASE pay close attention to the wires there are about four on each switch. You do not want to get them crossed.
----------------------------- Ernie 81 SC |
You guys were right. It was the switch.
1984 Carrera |
