964 calipers modifications
I need some help with a question on an old subject which I cannot seem to answer with the search button.
I'm thinking of fitting the VCI modified 964 calipers over the 86 944t 28mm rotors as shown on the VCI site. A quick check through the archives and Bill V's brake page says that the 964 calipers will also fit over 930 32mm discs I want to start with the 944t 28 mm discs and if there is still a heat heat problem on DE days add the 930 32 rotors as an upgrade Do the calipers need any further modification to fit the 930 32mm discs other than slightly greater radial offsetting through the radial adapter? what about caliper throat widths etc? thanks
Bruce 83 SC 94 993 |
Good questions. I too am curious about the answer, as I have been considering this upgrade and would likely go straight to the 32mm rotor if it is possible.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
MBruns for President
Easier to fit the 993 calipers
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I'd go with the rotor that does the job and no more. Have you weighed a 32mm rotor? Not light, but required if you need the mass.
Sherwood |
Anyone know the approximate weight difference between a 28mm 951 rotor and a 32mm floating rotor?
Also, the beauty of a 964 caliper is that youu can still use the Carrera rear caliper with a 24mm rotor, which makes thing significantly less expensive.
Thread Tools | |
Rate This Thread | |
