Help identifying a wire please
This wire enters the front trunk area next to the small washer pump. As it is brown, i want to believe its a ground...but it has a terminal connector attached (PO). so i am unsure if its a power lead or if it was initially attached at the body ground.
It appears to be factory...The picture isnt the best... Any help appreciated!!
86 911 Targa |
Insert Tag Line HERE.....
its definitely not factory. They would not run a wire through the sheet metal without some type of grommet. Where does it go? aftermarket fog lamps? cooler fan?
Marc |
JOT MON ABBR OTH
Could you post a little clearer photo and a photo of where the other end of the wyre goes? Thanks.
David '83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)'15 F250 Gas (Her Baby) '95 993 (sold )I don't take scalps. I'm civilized like white man now, I shoot man in back. |
I will try to get a better shot. I assummed it may have been factory just because of the way it comes thru the sheet metal. I can't see where the other end goes as of yet, that hole is covered by the front bumper. No aftermarket lights, alarm, etc. everything appears to be original.
86 911 Targa |
Seems like someone would have gone thru a lot of trouble to fish this....
86 911 Targa |
Not factory. Maybe remote radar, alarm ????
JOT MON ABBR OTH
Where does the end coming towards the camer go?
Looks like some other wires spliced in there as well.
