| toby1 73t |
05-27-2007 12:41 AM |
Over the years the clock's lubricant hardens and is the primary reason that the fuse link blows
that makes no sense to me. if the lubricant hardens all it would do is stop the spring that makes it run the fuse link is only activated in the process of rewinding the spring so if the clock slows or stops it has no effect on the process of rewinding the spring which happens in a split second when the points touch. I don't think you will have any electrical event when you hard wire and put a .75 amp in line fuse right before the clock. Maybe other clocks are build different then mine but I'm sure thats how mine works. On the other hand my clock is running twenty minutes slow every two days so if the adjustment screw on the back of the clock will not correct I'll clean and reoil. i agree that is way his clock would stop on a cold day but i don't think his fuse link is blown or it would not restart.
