lespaul's Avatar
dead starter and waving tach issues
Yesterday, about 60 miles into a 240 mile round trip, I stopped for gas. Filled up, started the car with no problem and drove for about 4 min to next stopping point. Turned car off. 5 min later, tried to start car again. No starter. Fuel pump was running, lights worked, but no sound from starter - not even a click. A friend push started me and she started right up. Idle was perfect and I drove another 100 miles. Engine performing perfectly.
Then tach began waving back and forth at me when decelerating. At idle, tach read 0 -- but car idleing fine. Tack did not wave when accelerating or holding throttle steady - just when declerating.
Before I dig in, I would appreciate any advice that might save me time.
Are the two problems likely related or just coincidental?
I plan to first check the ground strap for the starter problem - but, if that was the problem would other electrical systems also have cut out too?
Could the starter problem be the ignition switch? If so, how to test it?
BTW - starter is 34 years old. If I have to get one for my 73.5T, any recommendations?
Brad
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 05-23-2007, 08:49 AM
Bad battery, alternator or voltage regulator on that order.
Old 05-23-2007, 08:58 AM
lespaul's Avatar
Thanks for the input.
Would it be likely that I could drive for 3 + hours after experiencing starter problems with a bad battery or alternator? Alternator light never came on either.
Brad
Old 05-23-2007, 09:07 AM
SCWDP911's Avatar
You might check out my recent thread. Seems like the season for this. Although, I do not have the wavy tacho symptom with mine....
Looks like I need a new starter...
Shane
- 1984 928S
Old 05-23-2007, 09:13 AM
lespaul's Avatar
Thanks V8 - great lead on next steps.
Brad
Old 05-23-2007, 09:21 AM
