911 Bad Idle and Odd Behavior!!! Help!
Been awhile since I posted. Moved from Denver to Philadelphia (no comments needed!). Here's my problem:
My '84 Carrera now exhibits two distinct problems: it idles roughly, and gets loopy at times, too. Loopy= idles high then low, and then repeats itself. The second is that after driving for a bit, say 15-20 minutes, it will not respond to throttle, like it is out of gas at other than idle rate.
Is this a COlortadop to PA problem? Is it two different problems or a linked one? Please help!!!
Old 05-22-2007, 12:20 PM
scottb's Avatar
The first thing I would do is take the car to a knowledgeable mechanic and get the mixture adjusted. The huge difference in altitude likely is playing a role in high/low idle, and may be the cause of the other problem as well.
1984 Targa
Old 05-22-2007, 12:37 PM
autovon's Avatar
Bite the bullet and take it to a mech. I was having the same rough idle problem (my mech called it "idle searching"), and although the fix was a bit pricey due to labor, mine runs superbly now and I couldn't be happier. Good luck.
von
'87 Cab
Old 05-22-2007, 01:46 PM
scottb's Avatar
I replaced a bunch of parts, and still my car had an idle hunting problem. I then took it to my mechanic and had the mixture adjusted. That solved the problem, and the idle has been rock solid ever since.
1984 Targa
Old 05-22-2007, 01:49 PM
Thanks, folks. I have an appointment next Wednesday.
Old 05-22-2007, 03:56 PM
