915 Trans with limited slip.......
How do I identify a 915 transmission with limited slip? I'm looking on transmission sitting on a pallet and does not know how to check or confirm that it has limited slip as claimed by the seller. What test or identifying mark do I need to verify it? Any help is very much appreciated. Thanks.
Tony
Old 05-23-2007, 02:49 PM
Crotchety Old Bastard
RarlyL8's Avatar
To be absolutley sure you need to pull the side cover and take a look.
Old 05-23-2007, 02:59 PM
Czar of C.R.A.P.
dfink's Avatar
Check the serial number on the tranny it will have a 12 stamped on it, if it was equiped with limited slip. Jack up the rear and turn one wheel the other side should turn the same direction.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 05-23-2007, 03:12 PM
Bill Verburg's Avatar
If it was an oem lsd it will look like this
originally posted by Hayden B.
this is a 915/73 w/ lsd as indicated by the 12 after the /73
w/o lsd
Bill Verburg
Old 05-23-2007, 03:17 PM
RarlyL8's Avatar
The trouble is you don't know if the LDS is still in there. It could have been removed long ago.
Old 05-23-2007, 08:58 PM
Immature Member
dentist90's Avatar
Grab one axle flange and hold it in place while you try to rotate the opposite one. An open diff will turn easily. LSD will be very difficult to turn at different rates / directions.
If it's stamped with a 12, but flanges don't feel stuck to each other, then I'd suggest you open the side cover to take a peak. Like Brian said, diff could have been swapped. Conversely, the case may be stamped as a non-LSD but had a new diff put in.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 05-23-2007, 09:08 PM
