removing stubborn 71 E outer CV's from stub axle.
mine are really on there - don't think they've ever been off. Any tips?
Old 05-24-2007, 10:07 AM
304065's Avatar
Once you have the bolts all the way out, there are a pair of roll pins that hold the joint to the stub axle. Also in there is a paper gasket. I would take a soft mallet and gently whack the side of the joint to break it loose. If that doesn't work, you can force a screwdriver in next to the gasket, preferably on the outboard end, and GENTLY work the joint loose. Take care not to scratch the surfaces, though: you don't want to hack a huge gash in the stub axle that will fling grease out.
Persevere and whatever you do make sure the car is properly supported when you are working under it.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-24-2007, 10:48 AM
thx John - headed for the screw driver now, 'tho I don't like it for obv reasons - "malleted" the hell out of it to no avail.
Chip
Old 05-24-2007, 11:39 AM
304065's Avatar
Make sure you have four paper gaskets from our host here for the reinstall. Don't forget to retorque a few days after the install, as the bolts WILL work loose.
'81 R65
Old 05-24-2007, 11:53 AM
randywebb's Avatar
plastic tent stake or the newer type - plastic - door shims
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-24-2007, 02:37 PM
