-   -   short shift kit issue (http://forums.pelicanparts.com/porsche-911-technical-forum/348383-short-shift-kit-issue.html)
the911Tprocess 05-24-2007 05:43 PM
I have a 72 911 T, I recently purchased a used shifter from a 73. It has the short shift kit installed (non factory). Fits great, feels great but I have a h** of a time hitting third.
I can hit fifth and reverse without any issues but hitting third and forth is difficult. What do I need to do to rectify this, I guess I will have to adjust the linkage. Any suggestions or knowledge that I can tap.
Thanks in advance,
the911Tprocess 05-24-2007 08:37 PM
any ideas
anyone any ideas
oregonmon 05-24-2007 10:40 PM
Not that I've done either of these, but people talk about changing the bushings and adjusting the clutch cable maybe.
aigel 05-24-2007 10:50 PM
Which aftermarket kit is it? If it is the weltmeister kit, you should throw it out and replace it with the factory short shift kit. My car came with the weltmeister kit and it was a POS. Way too short, so the planes 1-2 were dangerously close to 3-4. I was afraid I'd money shift it eventually and installed the factory short shift with all new bushings in the linkage and coupler.
George
the911Tprocess 05-25-2007 06:33 AM
short shift kit
Thanks, I was afraid of that.
aigel 05-25-2007 08:37 AM
It really isn't a big job and you don't even have to jack up the car or lay on your back either. ;) I think the factory short shifter now is available again, if I remember right. When I bought mine, it was NLA and the parts places started charging extra for the few they could still find. If they are NLA, you may find one in the classified section if you place a wanted ad.
Good Luck!
George
aigel 05-25-2007 08:50 AM
Here a few pictures for ID:
The weltmeister kit in package (Sherwood (911pcars) posted this in an earlier thread) http://forums.pelicanparts.com/porsche-911-technical-forum/190558-what-about-short-shift-kit.html
http://forums.pelicanparts.com/uploa...1099539013.jpg
And the kit installed. The tell tale sign on the weltmeister is the big spacer under the housing (from http://forums.pelicanparts.com/porsche-911-technical-forum/347985-help-identifying-shifter-915-a.html):
http://forums.pelicanparts.com/uploa...1179873481.jpg
Here is what you are after. The entire factory kit. Bill V. posted this in the first thread referenced.
http://forums.pelicanparts.com/uploa...1099528253.jpg
Have fun!
George
the911Tprocess 05-26-2007 08:27 PM
got it
Got the kit as discussed. Will install when I receive it and report back.
thanks for the advice.
mhackney 05-30-2007 06:14 PM
So, the factory kit is listed for years 72-86. What options are there for those of us with, say, a 1970 911S?
thanks!
Michael
jasam 05-30-2007 06:24 PM
I went for the WEVO coupler and the WM SSK and it's amazing, I don't hace ANY problems with it, I changed the bushings and installed the coupler at the same time... It is wonderful... Like John Cramer said I wouldn't trade it for any aftermarket shifter...
911pcars 05-30-2007 11:27 PM
thanks!
Michael
Install a 73-86 915 shift housing and remove its reverse lockout pawl. Same bolt pattern to mount onto the tunnel. Shift pattern and detents are inherent in the gearbox, thus the shift lever merely transfers the proper shift motion into the gearbox.
This is our kit installed on a modified 915 shift housing. There are other manufacturers that provide similar shift features.
http://forums.pelicanparts.com/uploa...1180592713.jpg
Sherwood
www.seinesystems
and available from our host
