Got stuck in 5th, what could be wrong?
I was getting off the freeway this morning and could not downshift, the car was locked in 5th. Got the car to the emergency lane and after a few seconds of moving the clutch and lifting and releasing the parking brake, it released and seemed like normal. What could be failing? Bushings were changed 3 years ago when short shift kit was installed. This has happened only once before that I can recall.
Modes of Transportation: 1984 Porsche 911 Targa 2003 VW Jetta GLI |
Less brakes, more gas!
This is an outside guess for your issue. I could be the accelerator or decelerator blocks jamming the synchro ring from disengagement... I had the opposite happen and this was the cause. I jammed the accel block in-between the synchro ring and the hub of the dog ring and could not put it in 3rd gear... It gradually got worse until I could not put it in 3rd ever so...
MY Fix was complete rebuild... to get there I had to take it all apart... Put in a new dog ring, synchro, and accel block... put it all back together... zoom zoom Until I took it all apart I did not know what was wrong, just that 3rd had disappeared... Sorry for some potential bad new$... Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Chris-
It may just be that you need to re-adjust the shift coupler. If the clamp on the shift rod isn't tight enough, the shifter can gradually slip out of adjustment. I hope this is your problem, because a transmission rebuild isn't cheap. |
Ferdinand Magazine
When I first bought my SC, I had this happen to me three or four times over a few weeks, always as I slowed after long highway sections. It took a lot of force to get the trans out of fifth. I changed the linkage bushes, adjusted the shift coupler and it has never happened again since. Hope you have the same success
Sheriff at www.impactbumpers.com Brand support at classicretrofit.com/tuthillporsche.com 1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles |
I had this when I installed my short shift kit (factory). If the shift coupler is set so that the gear lever does not travel sufficiently forward when engaging fifth gear, then the lever will not clear the reverse lockout mechanism entirely. When jammed, moving the lever further forward and to the left may allow the reverse lockout enough room to relax into its correct position. Careful when adjusting the shift coupler, though, 'cause if you set the coupler with the lever too far forward then the tab welded to the side of the lever won't come back far enough to clear the corresponding tab on the shift tower in neutral and you won't get the lever out of the 5th/reverse plane.
Good luck and happy fiddling!
1982 911 SC coupe RoW moss green SSIs and M&K 2-1 muffler |
What is a: accel block... |
Thanks everyone, I will take it slowly to see how often this happens and in the mean time start saving for a replacement transmission. One of the previous owners had it rebuilt about 1998.
Immature Member
If it happens again try pushing the lever even harder into 5th (ie, forward). If you are then able to get out of 5th easily it is your coupler adjustment. That 5-R lockout cam can get wedged in behind the shift lever if it doesn't travel forward quite enough, as Rootmatt correctly pointed out.
I have found fine-tuning the factory short shift for proper 5th gear operation challenging. Beware: setting the linkages with 5th gear too far forward may result in difficulty getting out of 5th without nicking reverse.
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
This happened to me shortly after I purchased my 1986. First, I noticed that after picking the car up from an attendant the shift knob had rotated about 15 degrees clockwise. Strange, but no problems shifting, until I got to 5th...then it wouldn't come out
. After tugging harder and harder it finally popped loose, and the knob had rotated back to its normal orientation. A few weeks later a similar thing happened, except that now I couldn't get it *into* 5th. It turned out that the upper and lower parts shifter are epoxied to each other. The epoxy had weakened and allowed the shifter to rotate. This caused problems with shifting into and out of 5th. Check if your shifter has rotated. If it has, this may be your problem, and you can either re-epoxy the shifter, or have it welded together as I did.
Tim '86 Targa Iris Blue '96 Audi A4 |
Well the problem reoccured today and I was able to get it out easier. I believe it is the shift gate because it seems if I give it a little push in 5th it seems to come loose but I had to bring the car to a stop to get it out.
I've had similar issue too, I just push it deeper into 5th then it pops out, it's only happened maybe 4 times out of 40K miles, so not too bad.
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
This issue is usually due to a slight mis-adjustment of the shift coupler.
Chris, if it happens again, try revving the engine a few times while you have the clutch pedal pushed in. It has worked for me. Then call Hergesheimer or someone you trust to adjust the coupler properly. |
stuck on 5
Happened to me 4 times today. I had to force it off 5.
It sticks even if the engine is not running. Shifter linkage adjustment ? |
One issue is the large hub that the 5th/reverse shift sleeve slides on gets deep notches worn into it in the 5th gear position, which tend to catch the sleeve.
Recreational User
I had this problem on my '86 Targa, and it was easily fixed by adjusting the shift coupler as described in Wayne's 101 Projects book. Try that first.
Mine was the reverse lock out pin needed some lube
