coil datas
Hello
Would you give me the resistance values to test my CDI coil, please ?
regards
Philippe
Old 05-26-2007, 11:07 AM
HarryD's Avatar
Philippe,
Whenever you have a question on Porsche Electronics, chances are that "Early_S_man" has already answered it. Do a search with him as the "User name" and the terms you need to find out about.
Using coil and ohms, you will find this post:
Bad Coil?
This should have your answer.
What is the problem you are having?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-28-2007, 09:39 PM
thanks
I've found this values, thanks
My problem, is sudden engine cut off (2.7RS engine), i'll try to eliminate electrical or ignition causes, if you have ideas....
regards
Philippe
Old 05-29-2007, 08:59 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Buy an MSD coil....#8222....relax....never have another though about bad coils again!!
Bob
Bob Hutson
Old 05-29-2007, 12:01 PM
thanks Bob
I've found a black coil ...
does your MSD have the same primary and secondary numbers ?
regards
Philippe
Old 05-29-2007, 12:57 PM
HarryD's Avatar
Hi Phillipe,
Lorenfb posted this on another thread (Do I need to replace my CDI box?). It should help you with your troubleshooting:
Loren sez:
"The diagnosis of this problem should take at most 5 minutes:
1. Get ANY known good ignition coil.
2. Make sure that the center pin of the CD box has a good +12 volts.
3. Make sure that the CD box case has a good ground.
4. Connect one terminal of the known good coil to the CD box output.
5. Ground the other coil lead.
6. Momentarily ground the pickup lead to CD box which will produce
a spark each time. Make sure nothing else (points, special pickups)
are NOT connected.
It's that simple!
Check here for additional info & specs (coil & etc.):
www.systemsc.com/diagnostic.htm
Harry
2020 MB E350 4Matic
Old 05-29-2007, 05:43 PM
