-   -   Shifter Adjustment Procedure for 83 SC (http://forums.pelicanparts.com/porsche-911-technical-forum/349382-shifter-adjustment-procedure-83-sc.html)
Max2.0 05-30-2007 02:26 PM
Back in January of this year, the Independent Porsche Shop that works (ed) on my 83 SC, stated that the car needed a new "Shifter Rod Coupling 91142402404" for which they charged $119.05 plus $127.50 for installation...
I did not notice that the car was shifting poorly b4 the replacement... Now, after driving the car for a few months, I find that 2nd gear doesn't downshift as easily as b4, and I am constantly "nicking" Reverse on the 5 to 4 downshift...
The 2 to 3 and 4 to 5 upshifts are not as smooth as I remember them to be either...
Soooo....I paid $250.00 (incl. tax) to make my car shift worse than before???
Is there a posted procedure describing how to set up the entire shift linkage for an 83 SC? Shifter is factory stock (no short throws or such). The Indie Shop is several states away, so no good taking it back to them; besides, they messed it up in the first place!
I feel this is within my abilities...just need some guidelines to follow to get 'er done! Thanks in advance!
SoCal70RSR 05-30-2007 02:45 PM
There are some good articles on this site under Tech Articles... this one comes to mind shifting improvements
There's probably one as well on how to replace all/most of the bushings. It should cost you a LOT less than what the shop charged you.
john walker's workshop 05-30-2007 04:39 PM
in neutral, loosen the nut/bolt on the rear of the shift rod, at the coupler. then center the shift handle, front to rear, in the shift tower, and hold the handle firmly to the left. then while you're doing that with one hand, reach back and turn the coupler to the right all the way and tighten the nut/bolt. that should do it. the shift handle with it's little lockout ear should now be able to go directly to the right without hanging up on anything in the process. do a minor front/rear adjustment if it does.
Max2.0 05-30-2007 05:27 PM
Since the wife says I'm dislexic, let me repeat the above instructions to see if I understand them...
Put Shifter in Neutral...(and lift the Boot)
Remove the Cover Plate behind and between the seats...
Locate and loosen the Nut/Bolt combo (is this a lock nut arrangement?) on the rear of the shift rod, at the Coupler (which I paid way too much for!!!)
Center the Shift handle, front to rear, in the shift tower...
Pull the centered shift handle firmly to the Left (Driver's Side) of the shift tower...
Reach back and rotate the Coupler completely to the Right (Drivers Side???) of the car...
Tighten the Nut/Bolt combo on the rear of the shift rod, at the Coupler...
If necessary, try more correctly centering the shift Rod in the shift tower, and repeat the above, until it shifts like a knife thru Hot Butta!!!
Okay, I made that up! Pleae confirm the above, and I will attempt it tomorrow... Thanks very much!
Two Tone 05-30-2007 05:31 PM
John,
When you say center it in the shift tower front to back, do you mean center it travel-wise or make it vertical (or does that equate to the same thing)?
I adjusted my shifter back a bit so that I didn't have to reach ahead as far when going for 3rd and 5th. Ever since then it is possible to nick reverse when going from 5th to 4th. I think I need to adjust it ahead some again by the sounds of this.
Two Tone 05-30-2007 05:38 PM
Max 2.0,
I'm pretty sure you need to rotate the shift coupler to the passenger side (Right side) of the car. That would be counter-clockwise if you are looking toward the rear of the car.
I'm glad you asked this question, I now have a good idea whats causing my 5th to 4th sensitivity.
Max2.0 05-30-2007 05:40 PM
Okay, I read the Tech Section articles and I think I understand the process now!!!
When John says "turn the shifter coupler to the Right, he means in a clockwise direction as looking toward the front of the car...
So the shift lever is going to the Driver's Side, and the Coupler is being roatated to the Passengers side of the car!!!
And yes, the lower portiion of the shift rod is to be at 90 degrees in the fore and aft plane, but tipped to the Drivers side during the adjustment process... By Jove, I think I've Got it!!!
Richard Burns 05-30-2007 05:44 PM
Before you remove the bolt nut combo move the gear lever from side to side so that you see what is happening. The coupler will move in the opposite direction to the gear lever( ie: gear lever to the left coupler turns to the right). Look at both the articles in the link I found the second one the easier although they both say the same thing.
SCWDP911 05-30-2007 06:12 PM
Sub'd
Mike Andrew 05-31-2007 05:00 AM
Subd
jmz 05-31-2007 07:41 AM
thanks for the great info to JW and all.
subscribed.
boyt911sc 05-31-2007 10:16 AM
JW's Instruction....
I got this same instruction from Mr. Walker about 8 years ago and had helped several friends using this method. This procedure is so effective in lining up your gears for easy and smooth shifting. Thanks a lot to JW.
TD
Porsche_monkey 05-31-2007 11:02 AM
Be prepared to make a few attempts at '915 perfection'. Do not give up if it doesn't work the first time, keep trying. And don't remove the rubber boot to make it easier to work in the tunnel. You will only have to undo your perfect setting to re-instal it later.
Sapporo Guy 05-31-2007 06:30 PM
cool, this is going to be helpful!
Thanks guys!
Max2.0 06-01-2007 01:59 PM
Hot Knife thru Butta!!!
WOW!!! I had no idea that a simple adjustment as John has given us, could possibly make such a fantastic difference in the shifting of the 915 Tranny!!!
I do not joke when I say it is like I just had a newly rebuilt transaxle installed!!! Every gear is smooth as silk now!
Absolutely NO sticking when downshifting into second...practically falls into place!
3rd and 4th just glide thru, and NO MORE NICKS downshifting for 5th to 4th!!! And Reverse is even easier to access! although it was okay before...
A couple of tips from "Sweaty Guy" (after working in the garage at 88 degree temps and 90% Humidity!)...
First unbury the shift coupler under the carpet and the steel plate at the rear of the cabin. Two 13mm wrenches do the trick to loosen the bolt and in fact it is just that, a pinch bolt!
Then, take a heavy duty rubber band or three, like come on asparagus or broccoli (yeah, i don't like the stuff, but the better half says I gotta eat it. :<((
Wrap the rubber bands securely around the vertical portion of your shifter (after pulling up the boot!).
Align your lower shifter portion vertically, to the left of the car, and 90 degrees from the floor of the car, and secure the ends of the rubber bands under the lip of the mounting flange and over the front and rear bolts that protrude upwards from the shifter base unit. This will keep your lower shifter nice and straight and tight in the desired position.
Then you are free to go to the shift coupler in the access hatch, and grip the coupler through the rubber boot with a shop rag. Try to rotate it from side to side. You will feel it move, rather easily. Should not have to force it. Rotate it as far to the Passengers Side as you can go. Hold it there and get a wrench on the 13mm nut of the pinch bolt. I found that one of those box end ratchet wrenches worked just right for this. Snug the nut down as far as you can. Put another 13mm box end on the bolt head, and lock it against your hand, while ensuring that the shift coupler is still all the way to the Passengers side. Finish tightening the nut down until it will not move further. You will know when it is tight! No need to torque wrench it, but okay if you want to. I would have to look up the torque spec for that nut. I'm guessing 15 lbs. max???
Then replace everything and drive off happily into the sunset! I was seriously thinking maybe I could use a new synchro ring or three...now, Smooth as a knife thru hot butta!!! You gotta do it! In fact, I would not be surprised to find that you could even improve on the original factory position if you did this correctly!
Of course, in my case, a PM had futzed with it and put in a new coupler (which most likely I did not need!!!) so he had screwed the pooch royally in the process... God, I hope he didn't screw up anything else! All runs great, so I will say my prayers tonight!!! Thanks again guys!
Porsche_monkey 06-01-2007 02:48 PM
So you paid $250 for.....
Fill in the blank please.
Joe Bob 06-01-2007 02:55 PM
Now go do a drive by on the wrench......
Max2.0 06-01-2007 03:07 PM
mikez, you have the right idea! Lets see...40 Cal. S&W, or old school 9mm Browning High Power??? Naahhh, Let's go with the Mariner SS 12 GA., with nine 00 bucks in the mag...
Oh, hell, it's my fault for not asking the right questions before he screwed me!!! Just bend over and get my annual proctological exam!!!
Anyway, I am loving the way the SC drives so much, I just don't care about the $250.00! BUT...I will have a word with the gentleman when I return to FL next winter!!! B4 anyone here has work done in Stuart, FL, drop me a PM and I will fill you in on the details...
Joe Bob 06-01-2007 03:21 PM
Yeah....the .40 would be too much. Howz about a flaming bag o'dogschitz?
SCWDP911 06-01-2007 03:21 PM
Well I had kind of figured my 1-2 shift was "just the way a 915 shifts", but I have to go try this out tonight. Max. how long did it take you? Does not sound like a long job if everything is handy.
