can't get my 78 3.0 to start
coil went bad (leaking silver) replaced it, had the cd box and new coil checked they work, replaced the green wire to the distrib. still won't start
I can get it to back fire if I keep cranking on it. getting fuel what else? |
make sure pop-off valve has not "popped off".. mine did a couple of years ago > $120 tow job home > I get it into my garage > open the air cleaner box > pop -off valve laying on its side > I re-seat > and it starts right up.. co$$tly lesson
kgl
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
3.0 liter motor.....
CIS or carbs? Would like to help but needs more info.
TD |
Home of the Whopper
Put a timing light on it and see if you get spark. That should at least tell you which direction to start looking.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
Remember that the distributor in a 3.0 turns counter clockwise - are your distributor cap wires on correctly?
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Black and Blue
also, if you smell gas, you might be flooding if the cold start valve is stuck open.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Is your distributor screwed? Mine just blew today ....
Carsten AKA Sapporo Guy ![]() 1982 SC -- US import it seems ... weeeeeeeeeeeeeeeeeeeee
Ok, well this was a good one. The good news is that it is fixed. the tab on the distrib cap broke off so it moved on off TDC....everytime I adj. the distrib it would get more off.
Thanks for everyone's help, I have good info for those who put 3.0's in earlier cars, the green wire to the CD box can be updated to Plug and Play. |
