Fahren mit dem Wind.
Can't shift into 4th or 5th
Just last week I was able to get my 70 911S back on the road after sitting for 2 1/2 years. The original problem was that the nut that held the pivot arm came loose - requiring pulling the engine/tranny and popping the tranny off to fix (I used the 71 upgrade fix). See Please help, the pain is unbearable for my recent posts.
Things have been more or less fine until coming home from work tonight. I can not get in to 4th or 5th - even sitting still. Could be related to clutch adjustment? I searched here but did not find a similar issue. thanks in advance, Michael
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net) Caregiver to: 1983 911 SC Cabriolet - Fahern mit dem Wind. (Moss Green Metallic over Champagne and Brown Leather) |
Sounds like you need to adjust the shift linkage as described in the tech section here:
http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm You might first check that the set screw that connects the shift coupler to the shift rod is not loose.
1969 912/6 Coupe 1970 911 T Targa |
C4 Pazzo, thanks for the tech article pointer. I thought the search feature searched the tech section too? Maybe not since I didn't find this on mysearch.
I will check that out. It makes sense since these were all disconnected when the engine was removed/replaced. Regards, Michael
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net) Caregiver to: 1983 911 SC Cabriolet - Fahern mit dem Wind. (Moss Green Metallic over Champagne and Brown Leather) Last edited by mhackney; 05-30-2007 at 06:46 PM.. |
Well, that indeed was the problem. A simple shift linkage adjustment and it shifts into 4th and 5th now. Of course I noticed that the bushings are worn and the rubber boot needs to be replaced too.
cheers, Michael
RETIRED
Yep...them 901 trannies with the old style shift pattern needs servicing every once in a while.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
