Start up Smoke
I keep hearing, and sometimes reading, that "all air cooled Porsches smoke on start up" if they've been "sitting for a while".
True? thanks |
Mine sure does - and I'll be damned if I can find any rhyme or reason as to when or why. Someitmes if it's sat for a long itme - sometimes if it had just been running. Sometimes it doesn't smoke at all.
Recently I have been letting it idle after driving to pump oil back in to the oil tank. I have no idea if this makes any sense, though...
David 1972 911T/S MFI Survivor |
Friend of Warren
They all don't smoke on start up, but a lot of them do. Nothing to worry about.
Kurt V No more Porsches, but a revolving number of motorcycles. |
If I dont run mine for 2 or 3 weeks it will set the smoke detector off in the garage.
Perfectly normal for a flat 6, dont worry too much.
88 carrera Using the teutonic shift method since 1990. |
If the car sits for a while I think the oil seeps past the the rings. Think of it as a "feature" of a flat, boxer engine.
If you over fill the oil you will notice this happening more often though. |
Administrator
Some don't at all. Some do.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
930s rule the wasteland
depends on milage and engine wear
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
My beef is that my engine only has a few thousand miles on it. Oh well - sometimes it's embarassing - and I coast it out of my garage before starting to keep my wife happy, but it hasn't caused me any trouble.
Anyone have any opinion about letting the oil pump refill the tank before shut-down?
Why yes, yes I do ![]() It works for me. I read that tip when I first got my car and it has worked great since. It really does work too because if I am in a hurry and don't allow enough time before shutting down, I'll get a puff on start up sometimes. Sitting doesn't seem to matter much, though my car almost never goes more than a week or so and is usually driven daily. -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
drag racing the short bus
Same with me. I let my car idle about twenty seconds after driving (or long enough to roll up the windows, gather whatever accoutrement I have with me), and shut down the engine. When next starting, no smoke.
Does the 911 owner's manual list a start up/shut down procedure?
The Terror of Tiny Town |
Wow - I did not now this was a common solution.
Well, I'm not certain it's a procedure that Porsche suggests, as I haven't seen it in a manual - maybe it's printed in other manuals, but not the ones I've seen.
I think the idle-after-driving exercise is much more important to the early 930 turbos.
I first noticed the "idle for a bit" method several years back and posted it on this site. It worked nearly 100% for me. I've seen several other folks post that it works for them as well.
It would be great to see some videos of what is considered normal smoke and what isn't. I can tell you that I still haven't figured my car out. I bought it back in November and the weather is just now starting to warm up. When my car would smoke on start up the previous owner told me that it's cold and it's condensation. The smoke is usually gone by the time i make it to the first traffic light leaving my complex. It seems to last longer if I just turn the car on and let it idle.
I haven't really tested it in warm weather yet to see if its condensation or not. I plan to take a video of it an post it so you guys can tell me what you think. |
Tim. 1988 911 Carrera. Silver. 1973 914 Metalic Blue. 2012 Cayenne S |
The amount of smoke that results from the first startup in the morning could also be a function of how well your rings have seated which would help prevent oil from seeping past them when the crank case oil level reaches the level of the cylinders overnight.
Joe |
you should warm up your turbo before nailing it , be easy on the turbo before you get to your destination and let idle for a little bit to cool down . this keeps the turbo from being scorching hot and cooking the oil in the turbo, which leads to clogged oil feed lines and wear on the turbo itself .
I seem to remember a thread about two check valves between the tank and engine. When the springs get weak (old) the oil can seep past causing this annoyance. Does anyone else remember this?
Just wonder if more oil is pumped to the tank at idle than during driving?
'87 3.2 Targa |
