Mitch Leland's Avatar
Transmission...
Howdy,
My burning question for the day: when I put the transmission into first gear, sometimes it doesn't want to go with the first try. I usually will put it in second, let the clutch out, then back to first. However at a stop light this takes some time since I don't leave the car in gear while waiting for the light to change. When the light goes green I always feel like the guy behind me wants to jump my bumper while I go through the gear thing.
The car is new to me and I haven't serviced the transaxle. Are there additives that will improve the shifting? Any and all suggestions will be appreciated.
Thanks,
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 06-01-2007, 07:18 AM
There is a good deal of linkage between your hand and the exact shift point. I would rebuild some of that. If it doesn't feel sloppy and its just hard to put into gear you may need to just replace your transmission fluid. Its a bit of a mess so you could have a shop do it for under $100 with fluid.
Old 06-01-2007, 07:29 AM
78 in a '71
mossguy's Avatar
Mitch - Last week I replaced my transmission fluid in my 901 with Swepco 201 from our host. It made a noticeable difference: quieter and smoother. Give it a try. Can't hurt, might help!
Tom
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 06-01-2007, 07:30 AM
Scott R's Avatar
I had this problem, searched the archives here and found out that a bunch of others did as well. I won't tell you to not check your linkage, because that's where you should start, however I needed a rebuild. I may be getting it back today, I know so far that it needed a 1st and 2nd syncro, and well the rest of the syncros as well.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-01-2007, 08:00 AM
19 years and 17k posts...
azasadny's Avatar
New shifter bushings and Swepco 201 will make a big difference, I bet!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 06-01-2007, 10:46 AM
THANKS...
I appreciate all the great input... I've ordered a gal. of Swepco from Pelican Parts and will give that a try. Cheap enough... I did talk to a Porsche mechanic today and he was doubtful it would do the trick, but hey, for fifty bucks it can only make it better. Since it's a new car for me, I find that unless you've been there done that you really don't know what some body else has done. Or not...
Thanks again... You guys make owning a Porsche in the "sticks" manageable.
P.S. Will you know if the shifter bushings are bad by opening up the inspection areas and wiggling them? Or are they under enough tension so they won't give you a visual indication?
Mitch Leland
Old 06-01-2007, 09:06 PM
also replace the engine mounts with WEVO mounts and the transmission mounts with sport ones and you will notice a marked improvement in shifting...
Old 06-01-2007, 09:19 PM
Irrationally exuberant
ChrisBennet's Avatar
It's pretty normal and has zilch to do with linkage IMO. Swepco never hurt anything though...
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-01-2007, 09:37 PM
Slumlord
Porsche_monkey's Avatar
Read this.
Shifter Adjustment Procedure for 83 SC
But don't expect any miracles. I always shift into second, then go to first to solve this. Or I let the clutch out, re-clutch and then go to first gear.
It will never feel like a 'good' modern day transmission.
Old 06-02-2007, 05:54 AM
