dazed and confused
windshield washer hose clamps
The clips securing the T's and valves to the hoses on my windshield washer system appear to be crimped on and not reusable. It seems the only way to remove them is to cut them off (like PEX pipe clamps).
Pelican shows this clip as #20 on the exploded diagram, but they don't stock the part and don't know anything about the clip. Before I pull this system apart, (and wished I hadn't), has anyone run into this before and what did you do? Did you just pull it all apart and just push it all back together using the same clamps? Did it leak? Did you find another type of hose clamp? If so, where did you get it? Thanks for any help here.
89 Carrera 3.2 Targa 2011 BMW 335d 2013 BMW X3 3.5 80 911 SC Weissach Coupe (Sold)
I've tried various methods. If the original clamp style was not badly damaged, it can be re-used. It works on the same principle as a CV joint metal band clamp, and there are special pliers that can be used to re-crimp. I've found access difficult for these very small clamps under the wiper area, when trying to use the crimping tool.
I've also used nylon zip ties as well as the very smallest hose clamps I could find. Depending on the circumstnaces...all of these have worked . - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
dazed and confused
Thanks, Wil.
The clamps appear in good order, that is they are TIGHT. I'd rather not remove these clamps as it doesn't appear they can be re-crimped...it seems they need to be cut at the crimp to remove them. Did you ever just pull apart the junctions from the hoses while leaving the clamps in place and then re-inserting the pieces? If so, did the system leak? I'd rather not have to re-clamp if I can help it for obvious reasons....
I used very small flat-bladed screwdrivers to gently loosen the grip these had....and sometimes you can re-bend them back using some sort of flat-jaw pliers.....
- Wil
Used Up User
Just buy some small 'geared' hose clamps from a plumbing supply/hdwe store. Cheap & easily found. That's what I used.
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
I replaced the T and non return valves on my windshield washer system about a month ago. I had a hard time removing the hose from the old valves and ended up cutting them off at the junction and fitting the new valves onto the washer hose. I didn't use any clamps, seems to be holding just fine with no leaks. It is a pretty tight fit by friction alone. That was the only way they were held on originally along with the rubber 'gaiters' which I re-used.
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon (new addition 1998 Mazda Roadster) EX - 1993 Porsche 911 Carrera 2 EX - 1979 Porsche 911SC TARGA EX - 1976 BMW 2002 |
Irrationally exuberant
Those "crimp clamps" are called Oetiker clamps. I get them from my local metric supply place.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Schleprock
www.mcmaster.com on pages 243 and 244 of the online catalog http://www.mcmaster.com/nav/enter.asp?pagenum=243
Kevin L '86 Carrera "Larry" |
Or.....you can buy them at your local Porsche dealer.
The factory part# for them is 999 512 527 00 They sell for just under $2.00 dollars a piece.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
heiliges blechle!
I cut the originals off and used a small clamp like the one pictured. I had to buy an assortment at the local auto parts place just to get a couple of them, I don't know how to buy just the small size I needed. These are pretty easy to clamp/unclamp in the difficult position they are in.
'84 M491 '07 Silverado '75 Suzuki GT550 2-stroke triple '02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train |
dazed and confused
Thanks guys, lots of good advice here. I'll get busy one of these weekends when I'm not out driving!
