My cruise control hasn't worked since I got the car over three years ago. No big deal since I don't use it. None of my trips have been that long or if they were they required plenty of input from my right foot. But it is one of those things that gnaws away at you to get it "right" with the car and have everything working.
I did the diagnostics test as outlined in the Bentley which pointed to the module as faulty. Then I searched (again) and found a thread which indicated the modules were prone to cold solder joints resulting in intermitent operation. Do you think I can find that thread now...Nope. So just to add to the vault of information this board is known for, here's my "testimony". I pulled the module and reflowed solder on suspect solder joints. This is all it took and now my cruise control works like a charm. I actually like the way it confidently "takes" the gas pedal from you with some "assertiveness" Although I've read other threads where some people have had the thing accidently engaged, and IIRC some situations where the clutch was depressed and the revs went out of hand (personally I can't see how that can be). Has anyone added a ON/OFF switch to the system? I may go that route. Anyhow, now it works!!The module is actually quite simple, one sided circuit, mostly discreet components with only a handful of active components. Seemed right that a little touch up with the soledring iron should fix it. Love this baord
Henri '87 Carrera coupe: Venetian blue |
sub'd
Shane - 1984 928S |
Bummer, I took mine out about a month ago. Oh well, I still would never use it.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
could you please tell where it is located and what it look like?
Fat butt 911, 1987 |
It's a silver box, approximately 5" X 6" , located just under the radio (at least in my '86 coupe.
Friend of Warren
I've had the same problem (intermittent working) and will try your solution!
Kurt V No more Porsches, but a revolving number of motorcycles. |
Throw it on the ground!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
On my 79 SC, it's in the trunk, behind the fiberboard cover, in front of the fresh air blower. Same silver box.
Trunk mounted at least through 1984.
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
Trunk mounted in my '85
Nick '85 Carrera |
I always wonder what the silver square box under the radio is. It look like a smaller version of the linksys internet rounter :lol:
I became all too familiar wth the wiring going into either side of that box when I mistakenly cut the cables while doing a radio install; who would put two wires of the same color in the same harness???? drove me ferkin' nuts!!!
Trunk mounted in my 80. Will try your fix and report back. It is nice to say "working cruise control" although it won't get used much if at all.
Also, did you add solder or just do a reheat on the iffy looking connections?
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
cruise box for sale
I have one for sale. Came out of a '77. Me thinks they were all the same.
How does $50 sound? Scott |
