Evil Genius
Rusty Heap's Avatar
My Painted Valvecovers - VHT wrinkle black - pics
Just got done painting my lower turbo valve covers with VHT wrinkle black, (supposed to be good for 350 degrees F) 3-4 coats over the period of 20 minutes, let them rest for 2 hours and then they started to wrinkle up. Put them on the BBQ at 150 for 2 hours, then 225 for 1/2 hour to bake the paint on, it was still slightly soft even after the BBQ.
Hit the raise edges with 100 grit sandpaper on a wooden sanding block to knock down the edges and bring out the pattern. I'm pretty happy with the way they turned out. Going to do the upper covers tomorrow.
Life is a big ocean to swim in.
Wag more, bark less.
Old 06-10-2007, 07:08 PM
pwd72s's Avatar
Cool. Looks a lot like the finish used on original 426 "hemi" valve covers back in the day.
Old 06-10-2007, 07:11 PM
I really like that look...any downsides that you can think of?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 06-10-2007, 07:26 PM
klaucke's Avatar
Harder to clean-- the paint is not smooth.
Old 06-10-2007, 07:28 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Looks Great...looks like my crinkle red intake manifold from my sti I had.
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 06-10-2007, 07:50 PM
Evil Genius
Rusty Heap's Avatar
Exactly, the paint isn't smooth, so the underside of the car engine with the wrinkle paint will hide any dirt and dust BETTER.
I've got an extra set of Turbo Valve Covers that I can do this finish on for you, if someone is interested in buying a set from me.
Old 06-10-2007, 08:06 PM
Harder to see where the oil will come from?
I had the thought of painting most of my engine white, to match the body.
Oil and dirt would be real easy to see...and thus clean.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 06-10-2007, 08:53 PM
Evil Genius
Rusty Heap's Avatar
Painting it wrinkle black gives you more low end torque and higher rpms, I believe the white finish provides better fuel milage as you're parked and cleaning it more than driving it. - grins
Old 06-10-2007, 10:24 PM
Evolved
Mo_Gearhead's Avatar
"White" = reflective = less heat retained
"Black" = absorbs = more heat retained
To a certain point, you want heat in cylinders and heads. For the rest of the engine (engine case, manifolds, attachments, etc) you want to shed heat.
Let the debate begin!
Don't fear the reaper.
Old 06-11-2007, 06:20 AM
I think its just paint guys, and both make more power than stock because it is modified.
Old 06-11-2007, 07:24 AM
TroyGT's Avatar
I love the look! Where did you get the paint?
+1 - The wrinkle finish will hold that oil drip just a few minutes longer before releasing it into the environment, saving thousands of gallons of oil each year. I think this is very eco-friendly and may positively impact gas prices as a result.
-Troy
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler,
Steve Wong Performance Chip
2001 Boxster 2.7L (Orient Red), bone stock
Old 06-11-2007, 07:41 AM
randywebb's Avatar
""White" = reflective = less heat retained
"Black" = absorbs = more heat retained"
____________________________________
This is incorrect as applied to paint for any temperature cooler than the sun. ALL non-metallic paint will appear BLACK to thermal radiation. It does not matter what color you paint the valve covers or any other engine part, including the headers.
No "debate" - Anyone can verify this by consulting a heat transfer course textbook, such as Kreith or Karlekar & Desmond.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-11-2007, 12:06 PM
That's why they paint black body radiators white.
Old 06-11-2007, 01:43 PM
Those covers look like my old set-- but mine were actually caked in grime and dried oil....
I think they look sweet.
1972 911T targa
Old 06-11-2007, 01:50 PM
Evil Genius
Rusty Heap's Avatar
Will someone who cares, please ask Jesse Jackson or Al Sharpton which color valve cover gets better treatment while getting arrested or jail?
Old 06-11-2007, 03:10 PM
purplehaze's Avatar
Dave -
They look great!
Mine are the exact opposite, powder coated. I like your crinkle coat look. Very durable looking.
Deja Vu - or Vuja De !?
Glenn
Glenn
87' 930TT
Old 06-11-2007, 03:25 PM
Evil Genius
Rusty Heap's Avatar
I'll post my top valve cover pics in a couple hours, they've still got an hour at 225 to bake in the BBQ..
PurpleHaze, MAN THAT TOOK SOME TAPING OFF WORK for the powder coat! smooth sweetness!
Old 06-11-2007, 04:19 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Dave-
Mine are the same, only I had them powder coated that way. Uppers and lowers.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 06-11-2007, 05:20 PM
Looks great! I just did a valve adjustment and missed an opportunity. Next time around I'm going for the Kringle black!
1989 Carrera Coupe (Black / Linen)
1981 911SC Targa (Black / Chocolate)
Old 06-11-2007, 08:43 PM
randywebb's Avatar
you can buy sets of used ones and swap silver/black/red when you do an oil change...
Old 06-11-2007, 09:41 PM
