I am looking to locate my engine cone on the engine, to verify which engine I have. I was told the engine is either a 72 or 73 2.4l with MFI. I want to verify. If you know where to look, please let me know. Thanks!!!
Look at your fan shroud...go to it's 3:00 position...then look down. There will be an upright casting on the engine case. The engine number is stamped there.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
OK, that worked!!! It was the ONLY place I didn't look!
Now, my engine number is 6130796 I have been told it is a 2.4. It has the mechanical fuel injection. I am now trying to determine if it is the "E" or "S" engine. From what I can see it is either a 72 or 73. I cannot find any where to decipher the serial number. Any ideas? Anyone? |
According to "The Porsche Family Tree", published by The Porsche Club of America, your engine is a 1973 911T engine...your relatively early engine number suggest that it indeed should be bearing MFI.
911T MFI USA There should another number close to the first that reads: 911/51
Robert Currently Porsche less (but the wife has 2) |
I guess I was expecting or more hoping that it woul dbe the "E" or "S" engine as from what I have found the "T" had carbs.
I just looked and cannot see a number beginning with 911/51. Is it on the same casting as the engine number or on the case itself? I appreciate everyones help on this! |
RETIRED
It's a LOT fainter but in the same general area....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
