Shifter install - don't do this
Installed new Wevo 915 shifter but ... when installing the shifter I forgot how the "free floating 'L' shaped bracket" went back on ... 4 plus hours wasted and after ordering new "L" bracket and finally decided to try it placing the bracket where it is supposed to be: the bracket fits under the shifter base and the bolts screw from base thru the bracket and then into the tunnel - I had been trying to install the bracket underneath the tunnel, i.e. screwing the bolts thru the base, the tunnel and then into the bracket - in other words, I am an idiot, but after stepping back, tacking a nap and rethinking and finally got it right - 5 minute job that I labored over for 2 plus weeks. Don't do it this way!
Goosh
Old 06-07-2007, 09:06 PM
dorschman's Avatar
but you will never get it wrong again.
87 911 coupe "Katy"
Summer Yellow
Linen Mahogany interior
04 Pilot "The Pilot"
Old 06-08-2007, 03:57 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
and thanks to Goosh, neither will we.
Anyway, how do you like it?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 06-08-2007, 04:17 AM
I think I vaguely remember trying to do that years ago when I first got my 911SC and was trying to sort out the mess that the PO had made of installing a short shift kit. It definitely added an hour or two to the job.
Last year I had that bracket out to replace the bushing (since I was replacing coupler bushings at the same time) and I actually got it back in the right place the first time. So there is hope.
Good luck
Scott
1978 911SC RoW
work in progress
Old 06-08-2007, 06:26 AM
man, you shoulda just posted a question on the board.
Old 06-08-2007, 12:38 PM
ncseahawk's Avatar
WEVO
I am installing my WEVO shifter now that I have conquered the pedal cluster.
Unfortunately I believe I damaged the hex head of the M6 bolt that must have been torqued to 1000 lb or something close....
Does anyone have any ideas how to extricate myself and the M6 bolt respectively from this predicament?
1985 Carrera Under Modification (SOLD)
2003 Carrera 4S
Old 06-13-2007, 03:59 PM
I'd switch to any number of bolt extractors on the market, such as the Craftsman set at Orchard Supply. Stay away from cheapo tools for this type of thing. You need something made with hardened steel.
Old 06-13-2007, 04:04 PM
