Tach a little lazy
About every other drive the tach in my SC takes a nap for the first few miles, slowly creeping up to the 3000 rpm mark and then after that operating properly. When I say slowly creeping up, I mean it will take about 1 mile to even move to the 1000 rpm mark and then about 3 miles to move to 3000. After that it usually kicks in and works, but it is fairly annoying and I don't want it to go out completely. Any thoughts on the cause/solution?
Mattlock18 1983 Porsche 911SC (Katarina) |
A recent Tach issue on my 81 SC led to the real problem.... the battery and charging system. Check your battery, voltage regulator, and alternator. Related searches will provide sufficient info.
Just a hunch.... ________________ Targa4now 1981 911SC Targa |
Will do. If that's the answer, you probably just saved me a couple of wasted hours.
Slumlord
The voltage/charging solution is usually offered up to solve the 'foating tach' where it oscillates, and over shoots. It;s easy to check the rnning voltage so do that first.
Your symptoms sound more like an issue with the tach's mechanical movement, it sounds like it loosens up and then starts to work. You might end up taking the cover off and checking the mechanics of the movement. You should be able to blow on the needle and move it.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
It's a sickness really...
I have the EXACT same issue with my 82SC tach. First I had the bouncing tach so the Alt was checked, new regulator installed, new battery installed and that problem went away (also installed cockpit voltage guage). I have assumed my lazy tach was a mechanical issue and if it gets to anoying, I'll pull it and check it out... Keep us posted on your progress!
'88 Carrera Targa (Venetian Blue) '08 Mini Cooper (Blue w/ white top) '91 Honda CRX Si (white 100% stock) '65 Mustang (cream - dressed as a GT350) |
I opened one up, and don't see any place to DIY any type of fix/adjust. I'll see if I can find it for pics, might be packed already though-moving.
Donnie Currently Porsche-less.....
MAGA
Re: Tach a little lazy
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Slumlord
A drop of light machine oil? Or a drop of WD-40 on the bearing?
I should note that mine also really only does this after sitting out in the sun. Generally it happens when making trips out to get lunch or when heading home from the office, but there must be a heat issue there somewhere. First thing the next morning it seems fine again. Since I know others have this issue I'll be sure to post any solution (if one can be found).
heat expands, so it may be the shaft inside the bearings expanding just a little. After looking at the insides...it seems to be a very delicate piece.
Try a sun visor on the windshield as a test
I was doing some searching, found this thread and since it's not too old thought I'd add another response.
My search was for "lazy tach" as that's what I've experienced a few times. It's been seemingly out of the blue and on very hot days too, as others above have posted. My symptoms are exactly the same as in the original post, although it's only happened to me a few times - today being the first in a while. My tach needle was very sleepy when I started up during lunch time - It was hot today. I didn't take too long, but over the course of about 3-5 minutes, it came to life and then worked fine. I never got any wild oscillations or crazy readings - it didn't budge when I first started the car, and then after 3-5 minutes, everything was working fine. I thought for sure I'd be in for a new alternator/regulator - maybe I still am, but I'm glad I found this thread. It makes me feel a little less nervous about the impending doom. A voltmeter is in my future! Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
