dweymer's Avatar
Ever replaced the engine/trans and forgot to:
Make sure the clutch fork engages the T/O bearing
I am getting very good at R/R!
I even used spade terminals last install just in case!
Donnie
Currently Porsche-less.....
Old 06-08-2007, 08:25 AM
vash's Avatar
yup. JP911 and i did that.
cantdrv55 and i, installed the motor to find out that we didnt push that TO fork shaft all the way up.
forgeting the starter ring gear? now that is just silly.
poof! gone
Old 06-08-2007, 08:29 AM
Senior Member
Superman's Avatar
BTDT. Kept adjusting the cable until I got action. The "action" was the fork bending itself against the transmission housing. Why can't the Germans just use a "push" pressure plate like everyone else. Who ever heard of pulling a TOB?
And on a related note, has anyone dealt with the clutch in a Rabbit. Goofiest thing in the history of motoring.
I can boast of never having failed to place the ring gear on the new PP.
Mocha 1978 911SC. "Coco"
Old 06-08-2007, 08:33 AM
Re: Ever replaced the engine/trans and forgot to:
BTDT Filled with oil and ready to go... or so I thought. I think an engine and transmission reinstall should go as follows:
1 Mate engine and transmission
2 Place in car
3 connect clutch cable
4 test for operation
5 If clutch pedal works, continue, if not go back to 1
Otherwise you'll spend a ton of time disconnecting stuff. That was such a buzz kill!
Neil
'73 911S targa
Old 06-08-2007, 08:43 AM
Nope, never had. Although I did other dumb things.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-08-2007, 09:07 AM
fastfredracing's Avatar
No, but I did mangage to put one in without the flywheel ring rear. zzziiiiiiiiing , followed by some choice words. Dont sweat it, we all make mistakes. I was in a hurry trying to make an auto cross the next day, that is why one should never rush.
No left turn un stoned
Old 06-08-2007, 09:30 AM
dweymer's Avatar
I thought i was taking my time! Took a week to replace the flywheel seal
It is my neighbors fault, he came over with his kid to talk. He really wants to buy one, but his wife says no. He comes over when the doors are open to see what it's like and get his dose of oil, gas smells!
Donnie
Old 06-08-2007, 10:45 AM
Slumlord
Porsche_monkey's Avatar
No, but I once forgot to make sure the throttle linkage didn't hang up at full throttle.
12,000 rpm cha-ching....$$$$.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-08-2007, 11:25 AM
dweymer's Avatar
ouch... well that was a fun fix!
Kinda nice working on it KNOWING you'll fix it!
Donnie
Old 06-08-2007, 02:44 PM
