der Mond's Avatar
Question More ride heightr/alignment questions
For the '87-89 Carrera, can anyone speak to the exact effects on the range of adjustment available with the rear camber and toe adjustment eccentrics by:
1) Leaving the rear ride height eccentric stock and lowering the car to euro height by re-indexing torsion bars only
2) Changing the ride height eccentrics adjustments
In other words, does the range of the adjustment of the alignment eccentrics change when one lowers the car via either re-indexing torsion bars or changing the ride height eccentrics?
Peace & Thanks,
der Mond
'87 Carrera Coupe
Venetian Blue Metallic
Old 06-10-2007, 09:42 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
The eccentrics have a specific range of adjustment that is constant regardless of the torsion bar indexing. You should be able to adjust the ride height through a range of about an inch or so. If they have not been touched since the factory, then you will only be able to raise the car with the eccentrics, since the factory set them to rest on their lowest adjustment so that the car would not settle after delivery, nor would it become a safety issue due to the ride height falling below the US minimum.
Nice color choice, BTW
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 06-10-2007, 10:03 PM
der Mond's Avatar
Thanks!
Peace & Thanks,
der Mond
'87 Carrera Coupe
Old 06-11-2007, 07:26 PM
