Alright....
I am in the process of installing some c2 / 964 rockers on my SC. I picked these up from Cory on off the used parts section. I have not made lots of progress, I am in the process of fitting and wanted to get some ideas for fitting these to the car. They are two piece and I have the main part attached by a screw in the front fender and some body tape along the top edge. I know this will never hold so I am looking for other ways to attach them. Any one done some like this before? Other question I had, the 2nd small part seems to lift off 1/4 off the body when overlapping the other rocker panel piece. Not sure if I need to fill in the gap or try mounting it under the main rocker.
Stephen Friendswood, Texas '78 Targa w/ '86 930/20 w/ '74 915/06 |
You will need to sand down the lip on the main rocker so that it is the same thickness as the lip on the rear piece.
cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Alright....
Well that was what I thought...
You may also try using some heavy duty two sided tape to mount the rockers to the body. There is a few automotive ones around that should help hold them on.
Cheers
Alright....
The small piece does fit sort of snug at the top. I also considered building the fiberglass up on the small piece close to the other FG part. Then taper it down as I go up.
I used a heavy duty 3M plastic Velcro, they are also bolted on the bottom and screwed on the ends. They were off a 91 and installed them to my 84, some of the material was removed from behind the rocker due to the thickness of the Velcro. I plan on using the factory gasket to fill in the gap along the top edge.
84 911 Euro 3.6 liter |
Alright....
I think you have the same bumpers as mine! The double sided tape does work but it is costly and hard to remove once on. I am pretty sure I can FB some bolts to the back side of the rockers and widen a hole where the original rockers mounted. At least towards the rear tire I can get my hand behind the mounting point. The drivers side will be a little easier because after I removed the old AC line it left some mounting points.
Thanks for the pic, your car looks great!
Alright....
84 Eruo,
Do you have a pic that shows how snug the rocker is to the car? Also, how did you determine if the rocker was level or what "lines" the rocker should follow? I just had mine go with the door line, it looks like yours starts a little lower and then goes up in the back.
No pics with me now, I will take a few next week and post. Used the door as a reference, here is another pic.
