window wiring SC 82
Anyone got that picture of the diag'
to hand I've got it in bits and forgotten now my own advice bugger it all
Nineteen Ninety One 964 Last edited by dependencies; 06-13-2007 at 04:34 AM.. |
No?
OK then try another tack. The fuse on the windows keeps blowing. When I swap it, both windows work, with their individual efficent speeds just as they have since I bought it Five years ago. The manual 964 engine cover spoiler I retro-fitted works, all is in fact fine.... I lock it up, go for a coffee come back out, and as often as not every time I go for riser switch (and before the window has even moved at all) its dead again. Even took a spare battery from another car and hooked it all up directly without a fuse and it works fine, Re-connected them as they should be to the car, via that last fuse on the board, wag the door to & fro, as they can chafe the wires there I know its fine windows operate the whole time, get out, leave it come back turn key blown fuse... any thoughts
Nineteen Ninety One 964 Last edited by dependencies; 06-13-2007 at 03:55 AM.. |
you lot are miserable today,
has someone nicked your wristwatches?
Nineteen Ninety One 964 |
