<insert witty title here>
Christien's Avatar
Performance test for CD box?
Is there any way to test the performance of my CD box? I know it's working in general - the car starts, runs, drives, etc. But when I'm at the track, running at constant high rpms, after about 5 or 10 minutes, I'm noticing a gradual but quick decrease in horsepower, to the point where after about 15 minutes on track I can't get above 5000 rpm in third gear on an uphill incline. I had a local shop owner/racer do a couple laps and he said he was pretty sure it was the CD box on its way out.
Is there any way to confirm this, without just replacing the CD and coil? I'll do that, and happily, but I've been chasing this problem from carburetors to fuel delivery to throttle linkages, etc. and I'm getting sick of throwing money at the problem and missing the target.
Thanks!
Chris
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 06-29-2007, 10:16 AM
Somatic Negative Optimist
Gunter's Avatar
That's easy, Chris.
Buy a used Bosch CDI module and swap.
I assume it's a 3-pin? They are cheaper than the 6-pin.
How is the green wire?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 06-29-2007, 10:56 AM
Christien's Avatar
Yes, it's a 3-pin (at least according to the guy who looked at it - I've never looked at it closely myself).
I'm going out to do some work on the car in about half an hour - what should I look for on the green wire?
Thanks!
Old 06-29-2007, 11:03 AM
Early_S_Man's Avatar
Porsche Crest
3-pin CDIs don't have a green coax or wire.
You can find in-car and bench check procedures in the Bosch Test document in the following thread:
History of Bosch CDI ... toubleshooting info, parts list changes, and schematics ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-29-2007, 12:15 PM
Christien's Avatar
Well, I just went and pulled it all out and put it back in. Definitely a 3-pin - green (could be blue), black and red in a rubber sheath that clips onto the bottom of the unit. There was also a single wire on a clip on the front - ground? Thing is, there were two clips on the front, one in front of the other, and there's only one wire (female end) to attach to it. Once I got everything back together I started the car to make sure it runs, and it did fine.
I opened up the CD box, and everything looked ok inside. In fact, I was surprised how clean it was. I took a pic but haven't transferred it from the camera yet - I'll post it once I do. I didn't mess around with anything in there because I didn't at all understand what I was looking at and didn't want to screw anything up.
Warren, thanks for posting that link - I had a quick look but don't have time to read through it all right now, but I'll read it all very carefully later tonight.
Old 06-29-2007, 01:01 PM
Porsche Crest
Chris,
The wire to the 'A' terminal [goes to the + side of the coil] should be Blue/Yellow striped. Red is your +12 Volt power lead, and black is the trigger from the points. There are, indeed, two folded-up 0.25" Faston tabs for ground on the 3-pin CDI unit's case, and only one wire to attach from the harness with a (female)Faston. There should also be another brown ground strap under one of the bolts holding the CDI case to the relay panel, and it should go to a bare spot on the fender to be grounded!
Warren Hall, Jr.
Old 06-29-2007, 09:09 PM
Christien's Avatar
Thanks, Warren. I'll double check the colours tomorrow. There was indeed a ground strap fastened behind the CD to the panel, going to a ground about a foot away.
Looks like I might have a line on a Permatune, so hopefully I'll get that swapped out this week then test it at the track this weekend.
Old 06-29-2007, 10:44 PM
