Garrison's Avatar
A/C not working
My climate control is not working in the car at all and I am wondering what might be wrong.
The rear defrost button lights up and the door lock button works, but the climate control knob for the fan, and A/C do not work.
I recently replaced the seats in the car with some aftermarket seats, and I did cut the wire that was connected to the drivers seat belt, but am assuming that this might not be the issue? or is?
Any ideas on where to start or what might have caused these 2 knobs to not work?
Thanks.
1996 Porsche 911
2013 BMW 335xi - Wifes car
2007 4Runner - 4x4 for Colorado snow
Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe
Old 07-02-2007, 06:36 AM
Garrison's Avatar
any thoughts?
1996 Porsche 911
Old 07-02-2007, 11:47 AM
To condense this down a little, the symptom is your AC blower does not work and the compressor does not come on???
Have you checked the fuse in the luggage compartment?
Old 07-02-2007, 12:39 PM
Garrison's Avatar
The fan does not blow at all, whether cold or hot air.
The climate control does not work at all... the fan or the A/C.
1996 Porsche 911
Old 07-02-2007, 01:15 PM
dshepp806's Avatar
fuses checked?
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-02-2007, 01:59 PM
The fuse that goes to the power seat also runs the AC in an 88.
I don't have the CC option but I didn't think it controlled the AC
Old 07-02-2007, 02:23 PM
Garrison's Avatar
Haven't checked the fuses... but that is the next step. Also going to reconnect the wires that I cut as I think one of them is the ground for the climate control unit.
1996 Porsche 911
Old 07-03-2007, 08:22 AM
esample's Avatar
Re: A/C not working
Thanks.
Whenever I troubleshoot, I always ask "what has changed or what have I done since XXX worked last? I would start back at the seat install.
-ernie
Black Widow
Blk on Blk '86 911
"...the secret to Porsche: we do things others cannot"
Old 07-03-2007, 08:38 AM
