Guys, I'm sure I'm not the first guy who owns a 3.2 Motronic Carrera who's had the plug-in from the wiring harness break off. So I'm wondering how you guys have fixed this issue. The yellowish plug that comes out of the harness over on the left side of the engine bay only has about an inch or two of wiring before it all disappears into the harness so that doesn't leave me a lot of room to try to splice in another one.
What have you guys done to remedy this situation? Right now I'm running without the O2 sensor because of this issue and wasting gas big time I'm sure.
You're not, get a weather pack connector or a flat four connector from the auto parts store and fix it. If you have a set of terminal tools you can make it look real nice, but it's not necessary.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Mine broke a few years ago and my mechanic spliced in some new wire to work with and somehow got the connector back on. Cheaper than buying a new harness. I'll try and get a pic or two in a bit.
Dave EDIT:spelling
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD Last edited by slodave; 07-03-2007 at 10:13 PM.. |
Thanks Scott and Dave. Working on these cars never ends...nor would I want it to. I love tinkering on them.
Dave, I'll look for your pics. (Scott, my last name begins with an R too, so I'm Scott R just as you are. )
Here's what I could get. I still have the old pin, but looks like I may be joining you in the repair. Anyway, you'll still have to find a new pin.
Notice the Mercedes symbol? ![]() Hopes this helps a little. Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Senior Member
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Alright, so here's how I fixed it.
I pulled the little bracket off that holds the harness side of the 02 sensor in place which gave me more room to work on stripping the wire down. I pulled about an inch of the blue heat covering off and then stripped the outer layer off the wire, which revealed the copper shielding. I then removed the shielding which, in turn, revealed the inner 16 gauge wire underneath. Next, I stripped about 1/3 of an inch of the insulation off and then crimped on a female bullet-type receptor. On my work bench, I cut about 6 inches of 16 gauge wire and attached a male bullet-type plug on each end. The male bullet for a 16 gauge wire just so happens to plug perfectly into the stock Porsche O2 sensor receptacle, so I plugged one end of the new lead into the new female receptor on the wiring harness side and plugged the other end into the O2 sensor. Perfect! Now, if I ever need to replace the O2 sensor, all I have to do is simply unplug it. I never need to worry about needing to strip that short wire down even more than it already is. Here are four pics showing what was done, from initial discovery through the fix: ![]() The stripped wire: The completed assembly (before tidying everything up and tie-wrapping everything in place)
Right on! Looks nice.
