leakdown vs compression tester
I have an 82 3-l sc engine which has been sitting for several
years. I bought it from a foriegn car repair shop that told me it came out of a customer car. Apparently, the shop told the customer that the engine was basically wore out. For $2k i purchased the engine which by the way is complete. I performed a compression test and here are the results cyl 1) 145 2) 165 3) 170 4) 160 5) 150 6) 175 I'd like oponions on these numbers. I've been told that old oil on rings can give false readings. Thanks in advance 81 911SC 76 911S 66 912 V8 71 914 project car 65 912 project car Kawasaki h2 drag bike Fast-by-gast |
Not much you can tell from that, you need a leakdown, and even then it's going to be somewhat inaccurate. I can say that when I lost the ability to fire #5 on my 3.0 it was around 140lbs, however it had a %52 leak as well.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
