leakdown vs compression tester
I have an 82 3-l sc engine which has been sitting for several
years. I bought it from a foriegn car repair shop that told me it
came out of a customer car. Apparently, the shop told the
customer that the engine was basically wore out. For $2k i
purchased the engine which by the way is complete. I performed
a compression test and here are the results
cyl 1) 145
2) 165
3) 170
4) 160
5) 150
6) 175
I'd like oponions on these numbers. I've been told that old
oil on rings can give false readings.
Thanks in advance
81 911SC
76 911S
66 912 V8
71 914 project car
65 912 project car
Kawasaki h2 drag bike Fast-by-gast
Old 07-06-2007, 08:33 AM
Scott R's Avatar
Not much you can tell from that, you need a leakdown, and even then it's going to be somewhat inaccurate. I can say that when I lost the ability to fire #5 on my 3.0 it was around 140lbs, however it had a %52 leak as well.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-06-2007, 08:35 AM
