-   -   Does this tail look right? (http://forums.pelicanparts.com/porsche-911-technical-forum/355767-does-tail-look-right.html)
twobone 07-05-2007 05:08 PM
Its a ROW 87' coupe
The Carrera script is set to high, no?
Is a Carrera script attached with a push rivet or is it "stuck on"
Can it be moved?http://forums.pelicanparts.com/uploa...1183684057.jpg
javadog 07-05-2007 06:14 PM
Way too high. Stuck on with an adhesive, so it can be removed. Buy a new one; they're cheap.
JR
porsche930dude 07-05-2007 06:21 PM
wow that looks weird i wonder why they put it there. Did they put that tail over the stock grille maby?
deshetlr 07-05-2007 08:17 PM
script is to high. May have been left in place when the wing was attached. Great looking wing. Should be stuck on. Check the underside to make sure, Remove and leave clean or check the threads on this board for proper placement of the script.
Bill Douglas 07-05-2007 08:46 PM
If it is stuck on get onto it with a hair dryer and start to lift it carefully to see if the paint will survive. No script is nice.
GeorgeM 07-05-2007 09:36 PM
Agree with Scott. Looks exactly like that. You can tell by looking underneath if the lid was drilled or came stock with the tail.
A good position is about half-way. No idea what the stock position is, I just eyeballed mine and put it where I though looked best.
rnln 07-05-2007 10:09 PM
I used hair dryer and fishing line.
Wil Ferch 07-06-2007 03:59 AM
Look here for factory sheet on script location--->
http://forums.pelicanparts.com/showthread.php?s=&threadid=307869&highlight=Carrer a+location
- Wil
EDIT--- translation: for Turbo, the distance from the bottom of the lid is 10.5 cm....not the 17.5 cm used for Carrera.
2.54 cm / inch.....someone's going to ask !
David in VA 07-06-2007 04:51 AM
I have the same tail, here are some pics of where my script is. I do know that a previous owner added the tail so I can't vouch for accuracy vs. the factory location but I think it looks pretty good.
http://forums.pelicanparts.com/uploa...1183726243.jpg
http://forums.pelicanparts.com/uploa...1183726258.jpg
deshetlr 07-06-2007 07:38 AM
Will, I have been searching for that thread for quite a while.
tcar 07-06-2007 11:04 AM
The best fix for this is to leave the script where it is and get rid of the tail. Ruins the lines of the beautiful body.
Like putting a backpack on a beautiful naked woman.
IMO.
rusnak 07-06-2007 11:22 AM
http://forums.pelicanparts.com/uploa...1183749661.jpg
It's about 7" from the bottom of the deckid to the Carrera script. Some people put the script lower, but to me it doesn't look right lower. I can post pics of the tail on the car if you want.
Wil Ferch 07-06-2007 11:46 AM
Well...the factory measurement of 17.5 cm from the bottom of the decklid equates to 6.88 inches...so 7" sounds about right.
- Wil
rusnak 07-06-2007 11:58 AM
there are times when .1" means a lot, and this ain't one of them.
Bill Douglas 07-06-2007 03:54 PM
I agree with Tcar - pics please.
