lv2race's Avatar
Ring and Pinion mesh pattern
I just set the ring gear in pinion shaft in my 901 transmission and then marked both the ring gear and pinion shaft with blue marker. Can anyone describe to me what a good mesh pattern should look like on the ring gear and pinion shaft?
Thanks for your help.
Rob
Old 07-09-2007, 08:47 PM
Designer King
Paulporsche's Avatar
If you search you will find a really good thread on R+P rebuilds. I think it was by RarlyL8.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-10-2007, 05:54 AM
vntgspd's Avatar
Do a Google search under "ring & pinion setting" and you will find lots of good info from the 4x4 guys. Great pictures included. I don't think this is something that you can "explain".
Good Luck!
Old 07-10-2007, 08:18 AM
David's Avatar
I'd also use something like a thin yellow or white paint rather than marker.
Old 07-10-2007, 08:57 AM
lv2race's Avatar
Guys - thanks for the help. I've got the information I need.
Old 07-11-2007, 12:02 AM
