| Registered Join Date: Jan 2006 Location: Rochester, NY
				Ring and Pinion mesh pattern
			I just set the ring gear in pinion shaft in my 901 transmission and then marked both the ring gear and pinion shaft with blue marker.  Can anyone describe to me what a good mesh pattern should look like on the ring gear and pinion shaft? Thanks for your help. Rob | ||
|  07-09-2007, 07:47 PM |
| Designer King Join Date: Mar 2004 Location: Toronto, ON Canada
			If you search you will find a really good thread on R+P rebuilds.  I think it was by RarlyL8.
				__________________ Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone | ||
|  07-10-2007, 04:54 AM |
| Registered Join Date: Jun 2004 Location: La Habra Hts, CA
			Do a Google search under "ring & pinion setting" and you will find lots of good info from the 4x4 guys.  Great pictures included.  I don't think this is something that you can "explain". Good Luck! | ||
|  07-10-2007, 07:18 AM |
| Registered |
			I'd also use something like a thin yellow or white paint rather than marker.
				__________________ 2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) | ||
|  07-10-2007, 07:57 AM |
			Guys - thanks for the help.  I've got the information I need.
|  07-10-2007, 11:02 PM |
