Intermittent no start
Tried several searches and couldn't turn up anything on this.
My '81 SC runs great but every once in a while, when I turn the ignition key, I hear the fuel pump run normally, then when turned to start nothing happens. Twisting the key back, then to start again and it turns over and jumps to life normally. The previous owner had the ignition switch replaced, I believe because it was just worn out. Is there a common relay that gets flakey? Is there known problems with the starter solenoids? The car has 144K. Naturally I'm concerned that at some point it won't start...
thanks,
mike
Old 07-09-2007, 12:42 PM
Scott R's Avatar
happened to me, same thing, but more frequently when hot. Starter had to be replaced, I purchased the hi-torque from our host. It's a very nice part.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-09-2007, 01:09 PM
Thanks, that's what I'm afraid of. Of course the next question is how difficult a job is it to replace?
mike
Old 07-09-2007, 01:14 PM
19 years and 17k posts...
azasadny's Avatar
Do you have a burglar alarm that is failing? My "intermittent no-start" problem was caused by an old derelict alarm that was wired into the fuel pump and ignition circuit...very frustrating!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 07-09-2007, 01:38 PM
No alarm on this car. Does anyone know if the starter solenoid can be replaced?
Old 07-09-2007, 01:58 PM
Slumlord
Porsche_monkey's Avatar
I bought a VW solenoid for $25. Problem solved. Go to a starter rebuilder, they will likely have it in stock.
Connect a trouble light to the solenoid. If it turns on with the key you know the problem is in the starter, otherwise it is likely a bad key switch.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 07-09-2007, 02:04 PM
