Exhaust Gasket Orientation?
Getting ready to put the new SSIs on my '78SC this weekend, and I notice that the stainless steel exhaust gaskets I ordered from our host have one side that is smooth, and the other side has a small crimped-style joint where the layers of gasket material are joined. Is there a preferred orientation for these, e.g., crimped side towards the cylinder head, or towards the header flange? Does it matter?
1978 SC Targa (mine since 1985) - ah, youth . . 2008 E63 2004 Van's RV-6 (O-360-A1A & Hartzell C/S) - just for fun |
Somatic Negative Optimist
How thick are these?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
But to answer the question I prefer the crimped side down toward the HE
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
I would go with the thick ones because I found that thinner ones develope blow-by when the flages are not completely parallel.
yup me to
Hmmm... so now what?
Well, I am not sure just what our host sent us. How do I tell, and should I be asking them to send a different part???
well like I said they both are the same part number just different manufacturers.. the ones I like btter are the ones that are thicker and are the same ones that came in my engine rebuild gasket kit from victor-reinz . I can tell you they both will work
Looks like the ones Pelican sent me are - per the web catalogue - made by Elring Klinger. I guess I'll put them on with the crimp side towards the heat exchangers and hope for the best..... At least there should be no issues with the M&K muffler and install kit for same, right Ben?
Is there a clear-cut answer as to which side faces the cylinder head and which faces the header?
📸 https://www.instagram.com/porsche.tech 📸 |
Crotchety Old Bastard
I don't know if there is a steadfast rule but we also orient the flat side (right) to the head and the crimped side (left) to the header inlet flange.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
I think it makes sense to do it like this as it's less likely to create an indentation in the softer aluminium heads.
It's a 914 ...
Well the exhaust experts say flat side to the head, so I’m going with that
Yep, steel side to the steel side.
3.2 exchanger gaskets are thick and compressable and rarely leak. Great for SSIs.
