I got it Out,.. 1st. Drop! Questions!
Easy Peasy! For a guy who has never really turned a wrench before,...I'm levitating! Ok,.. but I've got Questions.... please.
First what is she,... she's a 78'SC targa, with about 100k. 1st photo,... my accomplishment. 2nd. photo. What is this? The black oval canister just past the oil filler neck, on the right side of the engine compartment wall. It has a 3-4ft. hose (cotton wrapping) which goes into the black nipple on the Air Box (3rd photo). Is this some kind of air filter? 4th photo. What is this? The backup switch wire and some wire that goes to the starter run thru it. Or is this a connector, does it open up? 5th photo. This is my speedo cable into the tranny. Do I have a manual or electronic? This board is the best,... wouldn't have even tried this fool hardy task without it. Thanks to all the past contributors! More questions to follow. Thanks Doug
Doug 78'SC Targa uno owner... moi' |
Re: I got it Out,.. 1st. Drop! Questions!
The black thing in #4 was the filler between the engine tin, you can see the gap in the pic. Looks like the "plug" may have worn down.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Jazzbase,... Is the charcoal canister a pretty much useless eco. add on that the factory did, like the air pump. I know just about everyone has nixed the air pump.
Same for this item? And if you nix it, do you just plug both in and out openings. Anybody else got one of these things. Doug
Dave, what plug? Is it a plug or a filler? I can see where it would fit in the recess at the fire wall. Is that all it does, or is it a connector box. Do the wires just run straight thru it, and there is nothing inside.
thanks Doug
Do a search here for "fuel vapor recovery" or "charcoal canister" and you'll find some good explanations of the system along with some diagrams. |
Jazz,... thanks, I wasn't even sure what to call the thing. I'll do a search.
doug
