Braiding on sparkplug wires, why?
Just curious as to why the factory wires are steel braided. Is it to protect the wires from rubbing each other, or is it to "ground" the wires. I will be replacing my original wires on my SC and noticed in the parts area that there are both braided and non braided wires.
The "collection" 1983 911 SC Targa (1 of 1430 imported) 1994 MB E320 Coupe (1 of 825 imported) 1992 MB 190E 2.6 2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
19 years and 17k posts...
The shielding was supposed to prevent electrical interference. It probably helps keep the wires from rubbing, etc...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
I thought it was the ground. I thought the hot wire is the core.
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
I've read it was to prevent the wires from cross firing which was a cause of the "exploding air box". In 84 they got rid of the the ss covering and used the regular Beru black wires. But I think they spaced them further apart.
Matt. 83 911SC 85.5 944 NA - Sold |
I was told by a porsche mechanic that iwas for preventing cross firing. I thought this to be odd, nothing else I have does this but I went with the ss anyway
'80 SC 911 '67 Chevy SS Nova - Supercharged '99 GSXR track only, '99 Superhawk '05 Toy PU - daily driver |
Actually it was to keep interference to a minimum, on early Blaupunkt radios.
Same reason early Corvettes did, reduce radio interference.
Air Medal or two
Remember, they have a solid wire core.................
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I read somewhere that it was put in to prevent cross firing, it was later determined to not help or cross firing was not the issue and took the brading off
Sold: 1989 3.2 coupe, 112k miles |
For all 10 yrs of it's life in a 911 CIS intake manifolds were susceptible to small explosions(those that have experienced one have found it to be very expensive and unnerving). There were many suspects as to the cause.
One of them was thought to be cross firing plugs. The solution was the ss braided sheath around the wires. SP2 is correct the braids are all connected to ground. I suppose that a secondary effect would be RFI shielding, but the primary RFI suppression is derived from the resistance in the plug connectors. Owners of '73 to ~'75(purhased new) recieved a recall letter to have the shielded wire retrofitted, by '76 it was standard(at least it was on my C3)
Attempting to eliminate the exploding airbox problem is the primary reason. The engines already met German VDE regulations [more stringent than FCC regs at the time] without the braiding. The 1974 brochure showed production line pics of CIS 2.7 engines with green shrouds and early-style unshielded Beru spark plug wires.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Soooooo, I guess everyone is saying stay with braided wires? It would look nice with shiny stainless steel versus what is there now.
Do you have a pop-off relief valve installed in your airbox?
If so, you can safely install early-style non-shielded wire without fear, or rebuild your existing wires [replace the wire portion only] as I describe in your other thread.
GAFB
Warren, I've got a fresh CIS 2.7 in need of plug wires - and I was sure hoping to drop $100 on early wires and not $200+ on the braided wires. Thanks for the info. (Pop-off valve is installed).
Several BMWs |
I got the braided Beru OEM wires and they look sooooo nice when they are new.
Stupid question maybe, but when do you know when you need new wires?
Is there a test or just when you have ignition problem?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
In that case wouldn't the root of the issue be one/more badly isolated cables? FWIW I went with the braided on mine two years ago...
'94 964 - Celebration 30 Jahre edition '06 997 - arctic silver with cocoa interior - sold '77 RoW 911 - black and still sexy - sold and I miss her '05 Audi A3 Sportback 1.9TDI (not a bad daily driver) - gone |
Designer King
What I've heard is that , while the braided wires were originally intended to help prevent airbox explosions, they in fact didn't achieve this, since most airbox explosions were found to be the result of a too lean mixture.
FWIW about a year and a half ago I switched to MSD wires to go with their CD and coil. They work fine.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
